help! bike is dead
Old Feb 6, 2006 | 03:53 PM
mookie's Avatar
Default help! bike is dead
so i went to jump my bike because it didnt start. This happened before so i knew what i was doing. However, when plugging the wires onto, the negative end touched some metal and now my bike is completely dead.
Is it just the battery that's fried? Or is it completely the circuitrythats f'd?
Please help!
pic of bike
Old Feb 6, 2006 | 04:17 PM
marmaladedad's Avatar
What did you jump the bike with? If it was from a car that was running, you may have overloaded the system.
How old is the battery?
Have you had this problem occurring frequently?
gsr-2nr's Avatar
Default Re: help! bike is dead (mookie)
If your battery isn't fried it arched start checking fuses you might have blown some.
Old Feb 6, 2006 | 04:25 PM
mookie's Avatar
Default Re: help! bike is dead (gsr-2nr)
i knew not to start the car. and this happened once before, so i wasn't too surprised to see this happen again. If a new battery doens't work, imma check fuses. and if that doesn't work, any ther suggestions?
Thanks for the input so far guys
EngineNoO9's Avatar
BEFORE you replace your battery check for an in-line fuse somewhere on the left rear part of the subframe under the plastics... You can find it easily by following the positive line coming from the battery backwards and it should be obvious as to what it is. I believe it's like a green fuse and I fried my fuse like that once. They're super cheap and easy to fix. Get a new battery while you're at it after you fix this
Old Feb 6, 2006 | 04:34 PM
mookie's Avatar
Default Re: help! bike is dead (EngineNoO9)
sweet thanks. I can't tell you how bad if reaked out when i saw sparks and the bike doing nothing.
Old Feb 6, 2006 | 04:44 PM
EngineNoO9's Avatar
did you mean to say that the positive touched the metal? the negative wire touching the metal shouldn't have done anything as it's the ground... I accidently touched the positive to my ground when wiring in my new RR and wasn't thinking about disconnecting the battery... I was real confused until I realized the obvious which is I arc'd it and fried the in-line fuse
Old Feb 6, 2006 | 06:58 PM
mookie's Avatar
opps yea thats what i meant, but you get the idea. i'll check the fuse tomorrow when theres some light out
Old Feb 6, 2006 | 11:50 PM
9deuce9rr's Avatar
good luck man.... i blew a couple 100A fuses on the old car back in the day. i'll keep my fingers crossed for you n hope that's all it is. i dont wanna hafta hear about you having to re-wire the whole damn bike.
Old Feb 7, 2006 | 12:50 PM
mookie's Avatar
sweeeeet checked the inline fuse and its blown. so i need to go buy a new fuse. w00t
Old Feb 7, 2006 | 01:06 PM
gulftiresinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">If your battery isn't fried it arched start checking fuses you might have blown some. </TD></TR></TABLE>
that SHOULD BE IT@!
Old Feb 7, 2006 | 01:18 PM
9deuce9rr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mookie &raquo;</TD></TR><TR><TD CLASS="quote">sweeeeet checked the inline fuse and its blown. so i need to go buy a new fuse. w00t</TD></TR></TABLE>
good to hear! now go do it on a car and watch the excellent display of pyrotechnics!
Old Feb 7, 2006 | 01:33 PM
EngineNoO9's Avatar
Default Re: help! bike is dead (WhiteLude)
glad to hear. Iwas 99.99% sure that was the problem. You'll get absolutely nothing if it's dead and be completely fucked until you realize what happened. I think $2 got me like 4 or 5 new fuses
nveley22
Honda Motorcycles
Sep 15, 2013 05:47 PM
gsr-2nr
Honda Motorcycles
Jul 12, 2008 06:04 PM
Matt Groove
Honda Motorcycles
Apr 11, 2005 06:08 AM
sshaikh01
Honda Motorcycles
Jul 2, 2004 12:30 AM
ShagginJet
Honda Motorcycles
Jun 2, 2004 05:05 PM
