Turbo F22 kit!!! Sorry
Ok I posted sorry mainly becuase I know questions like these get asked all the time, I tried to look up my answer but just got frustrated looking so I decided to ask. Ok I have a 94 and a 95 accord, the 95 has a 98 VTEC F22 motor and the 94 has a NON VTEC F22 motor in it. I want to fix one up for a little toy but am not sure which one. I want to throw a little turbo onto one with some new pistons and rods but am not sure which would be better. So....
F22 VTEC with a turbo?
or
F22 NON VTEC with a turbo?
both motors have like 72K on them and they are also both automatics.
almost forgot whats a good kit to stick with also. not looking for 1000 Hp but looking to get some good numbers
or
Well just to warn you.It's alot harder then just throwing on a little turbo.you will need a way to manage the engines spark timing and fuel ratio.You need to retard timing as boost comes on.ANd you need to add fuel as the boost increases.
It takes alot of research to learn what you want and what realistic goals are with a turbo it really comes down to your budget.
but to answer your question.I think the vtec engine would be better.Ive read in the forum doing SEARCH'S that alot of tuners adjust the onset of vtec to help spool the turbo.
But Ive read alot about the older f22 none vtec engine.Because thats what I have and it would be pretty easy because you can use the manifold and turbo from DSM 90s turbo model eclipses talons and lasers.
and the 450 injectors.
so that way is a little cheaper.But cheaper isn't always better.
The most Ideal turbo Ive found IMO for the f22 is the GT2854rs but it's expensive
t25s are way to small for a f22 engine
