overheating and coolant overflow?
im frigin stump and pissed. here we go i have a d16z6 fresh rebuild with 20 overbore pistons eagle rods and springs retainers and a comp cam. well i have a greddy 15g turbo kit and boosting 15 lbs tuned well i go to get on it and it pushes the coolant to the resivior tank and fills it up and shoots it out. ive checked and checked i couldnt find and fluid mixture or anything and it doesnt smoke and still runs and starts good. this weekend i switched the thremostat and put a electric fan on it and it still does it. anyone have ne ideas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy »</TD></TR><TR><TD CLASS="quote">head studs are stretching, you need a new headgasket and some arp headstuds</TD></TR></TABLE>
I agree its HG... so you'll want to put a new one in... and if you don't have headstuds (ex: ARPs)... you should get some.
i forgot to mention i do currently have arp's in the motor and it was a fresh head gasket is there any other things it could be its only when i get on it. could it be the radiator i have to stock small one ? idk if it is the headgasket could a bunch of **** be fucked up>? and can i reuse the arp's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic94 »</TD></TR><TR><TD CLASS="quote">i forgot to mention i do currently have arp's in the motor and it was a fresh head gasket is there any other things it could be its only when i get on it. could it be the radiator i have to stock small one ? idk if it is the headgasket could a bunch of **** be fucked up>? and can i reuse the arp's?</TD></TR></TABLE>
ARPs are reusable. When the motor was put together... did they check that surfaces were level? Is the first time you've used the ARPs?(if so... did you retorque them after a few heat cycles?)
yes this is my first build and no i didnt retourque them , im guesssing thats a nessacity? if so is it too late to go back and retorque and that fix it? if so do i retorque to 60ftlbs or what thanks for the help this ***** stressin me
i first torqued to i belive 30 then 60 but never retourqued after heat cycles so if i retorque now what should i torque it too? and does anyone know if ineed to change the hg too or just retourque
ok so u think the stock 11 year old radiator and cap has enough to suport the 250 whp? at 15psi? if so ill just grit my teeth and rip this bitch apart and swap hg's has anyone else had this problem could it be my block guard???
