brake problems
i own a 1994 honda civic eg4 1.5 vtec and a couple of days ago i was driving and the brake light inside the dash came on, a couple of minutes later the brake paddle went soft and i had no breaks. the break fluid vanished from the master cylinder and i can't find any leeks. pls help
follow all your brake lines starting from the master cylinder. check for any wet areas by filling up your brake master cylinder with brake fluid and putting baby powder on the suspected leaking areas and watch for any caking of the powder. if nothing its most likely you master cylinder has a massive leak and is leaking around firewall. if so, replace your master cylinder.
The_In_Kid
Jul 7, 2002 11:45 PM
