H22 head torque specs?
Old Feb 6, 2006 | 08:34 AM
egvtec's Avatar
Default H22 head torque specs?
Is there anywhere online or anyone who has the specs for the cam caps, and the head studs? I am installing my head and need the specs thanks
Old Feb 6, 2006 | 08:39 AM
egvtec's Avatar
Default Re: H22 head torque specs? (egvtec)
Someone confirm theese specs?
Head bolts 72.3 ft lbs , Cam rail covers 19 ft lbs?
Old Feb 6, 2006 | 08:42 AM
GSRpoweredEJ's Avatar
I don't know the specs, but have you checked out any local automotive department stores for a repair manual? I'd emprovise you get one if you plan on getting more technical with your car.
Old Feb 6, 2006 | 09:16 AM
egvtec's Avatar
Default Re: H22 head torque specs? (GSRpoweredEJ)
I have had all B series before and i pulled the head cause the belt snapped. I do all my own mechanical work i just wanted to get the specs of here before i go out an buy a lude manual, since i do not plan on removing the head again after this
Old Feb 7, 2006 | 07:08 AM
egvtec's Avatar
So what are specs for the long aluminum covers over the cams, and also the "u" shaped pieces that hold the cams themselves down over the rocker arms.
Old Feb 7, 2006 | 08:57 AM
SP GARAGE's Avatar
i believe you trq it to 23lb-52lb then 72/73lb its been a while since i trqed my head
Old Feb 7, 2006 | 09:43 AM
egvtec's Avatar
Default Re: (mixxxwell)
yeah thats head bolts, i need the others for the cams
Old Feb 7, 2006 | 12:08 PM
egvtec's Avatar
Default Re: (egvtec)
bump for cam bearing specs and cam covers
Bxjay16
Honda Civic (2001 - 2005)
Feb 4, 2014 04:59 PM
itr1244
Jul 27, 2009 07:24 PM
95teilhatch
Jun 25, 2007 01:20 PM
miahmouse
Jun 8, 2004 06:19 PM
