AC Bracket on b18c5
Old Feb 6, 2006 | 07:25 AM
Nicram's Avatar
Default AC Bracket on b18c5
Like the topic says, I have 94 Hatch and I need the AC bracket/mount. Will any bracket from b18 will fit?
Old Feb 6, 2006 | 07:42 AM
Luserkid's Avatar
Default Re: AC Bracket on b18c5 (Nicram)
You want the bracket to use AC or just to hold up the motor?
For AC you need the DOHC Del Sol bracket. To hold up the motor you could use the C5 bracket with civic mounts.
Old Feb 6, 2006 | 07:47 AM
Nicram's Avatar
I want the bracket that holds the motor, the same bracket where ac is mounted.
Old Feb 6, 2006 | 08:43 AM
Nicram's Avatar
I do not have any mount in front. I want to get one and I am wondering if the b18 front mount ( the one where the AC is mounted to ) will fit.
Getting the c5 is kind of hard and expensive
Old Feb 6, 2006 | 08:44 AM
dwnthehatch's Avatar
Default Re: (Nicram)
If you don't have ac you can use the c5 bracket.
Old Feb 6, 2006 | 08:47 AM
Nicram's Avatar
I do not have and I will not have it, I do not have the bracket at all!!!
GSRpoweredEJ's Avatar
I think all b series should share the same mounts/brackets. I have one from my gsr that I don't need.
Old Feb 6, 2006 | 08:57 AM
Nicram's Avatar
NOw will it fit from the 90-93 B Series?? Since they are most commonly represented at junk yards.
Old Feb 6, 2006 | 11:05 AM
Nicram's Avatar
Bumpie
Old Feb 6, 2006 | 01:11 PM
Default Re: AC Bracket on b18c5 (GSRpoweredEJ)
I have 4 b series brackets sitting in my garage. email me. dwnthehatch@yahoo.com
Old Feb 6, 2006 | 02:46 PM
DelSolMarine's Avatar
Default Re: AC Bracket on b18c5 (dwnthehatch)
when i bought my motor i had to get the Del Sol B16 AC Bracket to hold the ac for the B18 swap... it pushes it back a lil
moco_machine
Sep 4, 2009 07:26 PM
keychild486
Jul 11, 2008 03:31 PM
uLikeMyPreludeSi
Oct 2, 2006 09:59 PM
Propulsion
Aug 12, 2002 10:13 PM
