parts needed 4 B16
Old Mar 25, 2002 | 01:32 PM
si foo's Avatar
Default parts needed 4 B16
Hey guy I was wondering what else parts do I need for my B16(SIR) to be drop in 90 civic si. So far I have the SIR with a B16a2 intake manifold, motor mounts from place racing, pwo ecu. I have the B16a2 axles will that work? Will I have a problem running the B16a2 intake manifold? I have both the motors B16(SIR) and the B16a2 all complete. What else should I swap between the two motors. I want to run the SIR instead of the B16a2 cuz of the OBD2................. thanks
Old Mar 25, 2002 | 01:41 PM
rainforest's Avatar
Default Re: parts needed 4 B16 (si foo)
you need upper 90-93 ls radiator hose and 92-93 gsr lower. a second one wire o2 sensor if not alklready had one. thats about it. it sounds like you are pretty done.
Old Mar 25, 2002 | 01:43 PM
Urban Business
Guest
Posts: n/a
you'll most likely need an adjustable shift linkage b/c the trans sits in a different place than before. you have the wiring harness?
Old Mar 26, 2002 | 11:39 AM
si foo's Avatar
Default Re: parts needed 4 B16 (TorteX)
I'm going to use my D16 engine harness. About the second o2 sensor the SIR's exhaust manifold has two sensors but I have a DC sports header off an ITR and that header has one hole for the o2 what should I do, where do I put the second o2?
scul8r1990
May 22, 2005 07:25 PM
MrEg
Oct 30, 2003 02:31 PM
xXTypeONegativXx
Mar 21, 2003 10:55 PM
keebler65
Jun 2, 2002 07:09 PM
