B16a2 O2 Sensor Probs HELP!!
alright....stock b16 headers have 2 oxygen sensors, just bought DC headers with only 1 oxygen sensor port.......what options to i have to run the engine correctly so it doesnt lean out
thanks....helping out a friend
H-T White Ops
Re: B16a2 O2 Sensor Probs HELP!! (mr_timluu)
You sure they have 2 sensors? I installed my DC SS 4-2-1 and I don't remember my stock manifold having 2 sensors. Just the one towards the end of the header where it bolts up to the rest of the exhaust.
Re: (mr_timluu)
2 options.
get an OBDII-I adapter and an OBD1 ecu.
or get this:
http://www.importparts.com/imp...&2D28
s
or get this:
s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_timluu »</TD></TR><TR><TD CLASS="quote">alright....stock b16 headers have 2 oxygen sensors, just bought DC headers with only 1 oxygen sensor port.......what options to i have to run the engine correctly so it doesnt lean out
thanks....helping out a friend </TD></TR></TABLE>
hmmm, you sure it's a b16a2? the 1st gen OBD0 b16's actually had 2 oxygen sensors right on the header. If that's what you have and NOT an OBDII b16a2 then ignore my above post. You can convert to OBD1 or just weld in another O2 bung on the header. Remember to hook the right sensor to the correct banks of cylinders otherwise one set will run lean and the other set will run rich.
s
s
