Oil Pan Interchangeability
What oil pans are interchangeable?? Meaning will the H23 oil pan work on the H22? Is there a difference between gens for the H22 when buying an oil pan, example will the 92-96 oil pan work on the 97 up H22's?? Can the F22 oil pan work on the H22?? Just wondering out of curiousity, thanks for any input.
I think this is actually a good question. I changed the oil pan on my 97 and I was looking at the oil pan trying to figure this out myself. If the only difference between the BB1 H22 and BB6 H22 oil pans are the use of a gasket or not then they should theoretically work. You still use a sealer for the BB6 you are just making your own gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">they will interchange...</TD></TR></TABLE>
No they dont. you're obviously guessing. see bottom post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio »</TD></TR><TR><TD CLASS="quote">all f22/h23/h22 are the same pan, the 97-01 pan is alluminum, and I have only got them to work with the pickup/windage tray from a 97-01 on the 92-96 motors.</TD></TR></TABLE>
this is possibly true. I know for a fact that you simply cannot slap a steel pan onto an obd2 block. I tried it just a couple of weeks ago. I still have the pan(now for sale). The steel pan will not seal up. it hits the pick up and you cant make it seal flush on the block. Also the aluminum pan has threaded holes in the bottom for a little bracket/flywheel coveer. this bracket also helps mate the tranny and the block together. you cant use it with the steel pan(obviously)
the 97 and up one is aluminum, vs the crappy metal 4th gen one.....
the 97 and up requires a little rtv application, the 92-96 uses a gasket, and some in the corners....</TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">when i said interchangeable i didnt mean that that was the only thing that needed to be changed....</TD></TR></TABLE>
All you said was one requires rtv and the other uses a gasket..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">your pickup and windage tray has to match your pan</TD></TR></TABLE>
Exactlt and what's so bad about the steel one it just holds oil. Not a big deal or anything
What are you trying to get out of swapping oil pans? Do you only have access to cheap used F22 pan or something?
If you want an oil pan .. get an aftermarket unit .. otherwise why not stay with the OEM one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skidtron89 »</TD></TR><TR><TD CLASS="quote">
Exactlt and what's so bad about the steel one it just holds oil. Not a big deal or anything</TD></TR></TABLE>
actually the aluminum pan has theses walls built into it my guess is to prevent oil starvation during cornering
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">
actually the aluminum pan has theses walls built into it my guess is to prevent oil starvation during cornering</TD></TR></TABLE>
Learn a new thing everyday
