800 to spend hat to buy!
Old Mar 25, 2002 | 01:20 PM
si91's Avatar
Default 800 to spend hat to buy!
i got 800 to spend on my b16 in my 91 hatch..i dunno what to buy help!!!!
Old Mar 25, 2002 | 01:26 PM
4g4me's Avatar
Default Re: 800 to spend hat to buy! (JDMb16a)
I would recommend at least the ITR intake cam, some cam gears if you don't have them already. There is always the aftermarket or type r intake manifold, and throttle body. You could get a nitrous kit with a fuel pump for about 800, if you want NAWWZ.
Old Mar 25, 2002 | 01:45 PM
Urban Business
Guest
Posts: n/a
Default Re: 800 to spend hat to buy! (4g4me)
im a drive train homo so i say lightened flywheel, act street strip clutch / their street/strip or drag pressure plate.
then itr intake manifold w/ tbody. injectors, fuel reg, cams, etc etc.
or 800$$ in hp stickers
Old Mar 25, 2002 | 01:49 PM
si91's Avatar
Default Re: 800 to spend hat to buy! (TorteX)
i got a CM3 now.. but 800 in stickers does sound NICEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!
Old Mar 25, 2002 | 02:30 PM
*Boostwerks*'s Avatar
what does your suspension look like?
Old Mar 25, 2002 | 02:35 PM
XPystchrisX's Avatar
Default Re: 800 to spend hat to buy! (Bryson)
if you're in need of a suspension set up and just want to get something that works... head over to http://www.nopionline.com and check out their spax psx suspension kit for the civic. i have one and i have nothing bad to say about it at all. very simple to install and the car handles beautifully. also the shocks that come with it are single adjustable... pretty good for 400 something shipped.
if you want to spend money on your motor only then i'd suggest dropping in a K&N air filter, get a header and having a custom exhaust made up. the custom exhaust is relatively cheap and the only real thing to eat up your budget would be the header. after you had that done you could probably still get a set of itr or ctr cams... buy those and you can keep your stock vavletrain and still be ok.
Old Mar 25, 2002 | 02:47 PM
si91's Avatar
Default Re: 800 to spend hat to buy! (XPystchrisX)
i alreay have a greedy exhaust
DC sports header
CM3
i have susension with tokico blues and neuspeed race..
it is soo hard making uo my mind i wat to ITR cams but i dont want t replace my VT with springs and all that stuff...
Old Mar 25, 2002 | 03:14 PM
maybe a 30 shot?
with the left over money you can make a kick *** fuel system to reliably support it
IMO
[Modified by Bryson, 4:14 PM 3/25/2002]
Old Mar 25, 2002 | 03:30 PM
bseriesrex's Avatar
To be honest I would buy some cams-camgears and maybe a flywheel.I have itr cams and hp cam gears for sale O would take 650 for them plus shipping.
Old Mar 25, 2002 | 03:41 PM
si91's Avatar
Default Re: 800 to spend hat to buy! (bseriesrex)
did u have to put in retainers and all that stuff what ECU are you running/?? bseriesrex???
Old Mar 25, 2002 | 03:47 PM
si91's Avatar
650 sounds good...if u want i am in MD how far is your city from md?
Old Mar 25, 2002 | 03:48 PM
RexB16's Avatar
you shouldn't, stock b16 valvetrain is good up to 8300 rpm and i have known wmany who gp 8500. its all a question of how worry free you wnat to be.
Old Mar 25, 2002 | 03:53 PM
RexB16's Avatar
Default Re: 800 to spend hat to buy! (RexB16)
oh and btw, go get itr cams, cheap cam gears and an itr inakte mani. that shoudl get you about 15-20 hp.
Old Mar 25, 2002 | 04:07 PM
si91's Avatar
hey rexb16.. i am running stock ECU redline is 8000. what ecu can take it to 83 with the cams?? wht kinda of times are i looking at with those mods? on street tires?
eg6 type-R
17
Nov 30, 2011 06:58 PM
2k1 SSM GSR
Feb 7, 2005 09:00 AM
KillerBTeg
Dec 18, 2004 04:28 PM
twin rex's
Mar 15, 2004 06:17 PM
Nighthawk GS-R
Apr 25, 2002 04:39 PM
