Idle blip
Old Feb 5, 2006 | 08:50 PM
uneek4dr's Avatar
Default Idle blip
After my car is warm the idle sits around 1k but it will drop about 1-200 rpms, its ever so slight but you can hear it if you listen and see the needle move. It has new plugs, what else could cause it to do that. Also when I start my car in the mornings it has a nasty metal tapping sound, not your everyday light tap but louder and it goes away once the car is warm. I know they have a little tap noise but this noise is different, like metal clanky.
Old Feb 5, 2006 | 09:48 PM
The_Sober's Avatar
Default Re: Idle blip (uneek4dr)
Is your idle surging, too? Or is it just dropping?
In regards to the tapping issue...check your oil level. If it's ok, you may want to do a valve adjustment.
Old Feb 6, 2006 | 02:21 AM
Skidtron89's Avatar
Default Re: Idle blip (The_Sober)
What's a valve adjustment?
Old Feb 6, 2006 | 01:28 PM
uneek4dr's Avatar
Default Re: Idle blip (Skidtron89)
The guy I got the car from said they just had the valves adjusted but im starting to think otherwise, what oil should i be running (5w30?)
the idle just barely drops it doesnt surge up and down it never goes past 1kwhen warm but will drop a tad and it only take a split second but you can notice it when paying attention
94accordexf22b1
Aug 19, 2013 12:11 PM
kornerk12
Mar 30, 2006 09:23 PM
Gump
12
Dec 5, 2003 02:11 PM
cjohnson_2
Aug 26, 2002 10:14 AM
