EGR removal .. no one has done it successfully?
Old Feb 5, 2006 | 07:31 PM
AccordRacing's Avatar
Default EGR removal .. no one has done it successfully?
Ive been doing a lot of research on removal of the EGR system and cant find one person that has cleared the ECU code without an AEM stand alone. Can an ECU chip clear the code? What about resisters at the plugs?
Old Feb 5, 2006 | 07:40 PM
prelude1897's Avatar
Default Re: EGR removal .. no one has done it successfully? (AccordRacing)
The EGR valve isn't hard to get out. Just use a small socket wrench and get it out. Just start of by getting it loose, then take it out with your fingers
Old Feb 5, 2006 | 07:41 PM
BB6racer's Avatar
the EGR valve is not hard to get around; as long as all the vacuum lines are attached the EGR valve will not cause any problems.
the problem is the IM pressure sensor. when the EGR valve opens, there is a slight drop in pressure, which the ECU expects to see when the valve activated. you would somehow have to trick the sensor to see the pressure drop when there isn't any.
i'm not too good with electronics, but anything is possible, right? it would take someone with quite a bit of electrical engineering knowhow and a lot of R&D. anyone fit the description, and want to solve a popular problem?
Old Feb 6, 2006 | 02:25 AM
Skidtron89's Avatar
The EGR is just not that big of a deal why expletive with it. If you gotta do something then take it off and deal with the code. It's not like the light on the dash is going to hurt you.
Old Feb 6, 2006 | 04:00 AM
I just remembered I have been getting the EGR code since I did my motor swap anyway haha .. it only comes on when I stay in 2-3000 rpms for 10 seconds. If i disconnect the plugs will the CEL stay on permenantly or only when it should be activating like it does now?
Old Feb 6, 2006 | 04:16 AM
mgags7's Avatar
my hondata doesnt throw an egr code, mine is disconnected and blocked off...
Old Feb 6, 2006 | 10:38 AM
ChrisRicketts's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">my hondata doesnt throw an egr code, mine is disconnected and blocked off...</TD></TR></TABLE>
same here.
Old Feb 6, 2006 | 12:39 PM
Skidtron89's Avatar
Default Re: (AccordRacing)
It should stay on permanetly
Old Feb 6, 2006 | 12:55 PM
DarkBB4's Avatar
Default Re: (Skidtron89)
If you are obd1 (older than 95) this is what you do to disable egr without getting the code
remove EGR valve with 1/4" wratchet with a 5-7" extension.. (its a 12MM) remove gasket and take to machine shop or buy online an aluminum egr block off plate (CP motorsports for like 10-20$)... Spray egr valve with carb cleaner and try to clean up...Put plate on, the egr valve.... Hook up all electric stuff and vacuum lines and uru good to go
Old Feb 6, 2006 | 12:57 PM
93h22a1vtec's Avatar
i have stock ecu with egr block off and the connector empty, i get codes randomly, anyone know if there is away to loop the 3 pin connector to get rid of the code, i heard there was but idk.
Old Feb 6, 2006 | 12:59 PM
DarkBB4's Avatar
Default Re: (93h22a1vtec)
well that means that ur egr is not hooked up correctly (not good vacuum ) or the acutally sensor is just broken...
you get them randomly cuz egr does not activate until ur 40+ mph (or so)... and when the car is at optimum temp
from what ive been told.. i think u can only just disable egr with stand alone tuning
Old Feb 6, 2006 | 01:37 PM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec &raquo;</TD></TR><TR><TD CLASS="quote">i have stock ecu with egr block off and the connector empty, i get codes randomly, anyone know if there is away to loop the 3 pin connector to get rid of the code, i heard there was but idk.</TD></TR></TABLE>
if your obd 1 then just leave the plate blocking it off, and hook up the electrical connector and vacume hoses and the codes will go away.
Old Feb 6, 2006 | 01:39 PM
TOP END MS's Avatar
Default Re: (DarkBB4)
I realize you can leave it plugged in .. but I do not want to do thaT! I want the system OUT. Is it posisible to get an ECU chipped to remove the ECU w/o expensive stand a lone?
Old Feb 6, 2006 | 02:15 PM
DarkBB4's Avatar
Default Re: (TOP END MS)
Yes
uberdata,crome.. etc.. will all work
Old Feb 6, 2006 | 02:33 PM
BB4's Avatar
BB4
i ahve the egr system completely removed in my car with a block off plate. it throws a code 12 but that code does not put the car in limp mode or affect the motor in any way. so it doesnt matter if it throws hte code, its no big deal.
Old Feb 6, 2006 | 07:13 PM
Default Re: (bb4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4 &raquo;</TD></TR><TR><TD CLASS="quote">i ahve the egr system completely removed in my car with a block off plate. it throws a code 12 but that code does not put the car in limp mode or affect the motor in any way. so it doesnt matter if it throws hte code, its no big deal.</TD></TR></TABLE>
correct, except you have to stay on top of checking codes, cause you wont know when you have another. plus i just dont like looking at that light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS &raquo;</TD></TR><TR><TD CLASS="quote">I realize you can leave it plugged in .. but I do not want to do thaT! I want the system OUT. Is it posisible to get an ECU chipped to remove the ECU w/o expensive stand a lone?</TD></TR></TABLE>
as bb4 said hondata ect will take care of it, but may i ask why you dont want to hook it up. do you just want it compleatly out of the engine bay, or have a mani w/out the port for it? with the blockoff plate and it hooked up, its still like its not there.
Old Feb 6, 2006 | 08:48 PM
LudeyKrus's Avatar
Default Re: (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
Or you could do like the guys did that owned my car before, and simply remove the CEL light bulb.....
PS - what's your # again, bish?
Old Feb 6, 2006 | 08:55 PM
BB6racer's Avatar
does the EGR bother you that bad? it cools down engine temps and reduces pollution, and it really doesn't kill performace. you will see bigger power gains if you get a straight pipe... i say keep the EGR, its not that big a deal.
Old Feb 6, 2006 | 09:13 PM
LudeyKrus's Avatar
Default Re: (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">does the EGR bother you that bad? it cools down engine temps and reduces pollution, and it really doesn't kill performace. you will see bigger power gains if you get a straight pipe... i say keep the EGR, its not that big a deal.</TD></TR></TABLE>
It's not really worth much unless you can completely get it out of your engine bay to clean things up. Otherwise, the "benefits" aren't really worth it all.
Old Feb 6, 2006 | 11:06 PM
TOP END MS's Avatar
Default Re: (bb4)
bb4 .. your CEL light is on 24/7?
Old Feb 6, 2006 | 11:24 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Haha sucks for you lude guys, I have a chipped P72 running my H22. This ECU doesnt even know what an egr is.(GS-R's dont have egr)
Old Feb 7, 2006 | 03:56 AM
DarkBB4's Avatar
Agreed, but when your EGR valve is stuck open.. Driving becomes unsafe and NOT possible.. I had VIOLENT! jerking and bogging.... to the point where i coudn't even drive on the road!!
Old Feb 7, 2006 | 04:08 AM
BB4's Avatar
BB4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS &raquo;</TD></TR><TR><TD CLASS="quote">bb4 .. your CEL light is on 24/7?</TD></TR></TABLE> no it goes off everytime i turn the car off and wont turn on until after about 5-10 minutes of driving
Old Feb 7, 2006 | 07:50 AM
EK9-Stealth's Avatar
Default Re: (bb4)
chipped p28 will take care of the problem.. so who has the whole EGR system they want to sell me? Everything..
I think this is from a USDM 97-99 lude
Old Feb 7, 2006 | 08:49 AM
evoalf's Avatar
Default Re: (EK9-Stealth)
i welded up my EGR ports and used p72 chip to vtec im not running knock and that damn egr. ill have pics of it later on.
