MPFI obd1 conversion
Old Feb 5, 2006 | 04:23 PM
SupraRXZ's Avatar
Default MPFI obd1 conversion
I am doing a MPFI conversion on a 90 dx Hatch
How do you Wire up the obd1 injectors on a obd0 harness? is there any write ups on how to do it, ive only seen the obd0 MPFI conversions is there any where you can use obd1 injectors and wire them on the obd0 harness without the use of a resistor box. I know it can be done i just need to know the steps on how to do it.
Thanks
Old Feb 5, 2006 | 04:26 PM
Pee Wee's Avatar
Default Re: MPFI obd1 conversion (SupraRXZ)
for the resistor box just cut it off and solder the wires together
Old Feb 5, 2006 | 06:40 PM
SupraRXZ's Avatar
Default Re: MPFI obd1 conversion (Pee Wee)
I dont have a resistor box, i have a DPFI car and im converting it to obd1 b series
Old Feb 5, 2006 | 06:57 PM
eda6's Avatar
the two yel/blk wires on the dpfi injector clips is 12V. Your obd1 injector clips will have a wire with a yel/blk stripe. Connect all the yel/blk wires.
SupraRXZ
Feb 3, 2006 02:15 PM
Patch
Feb 29, 2004 07:21 PM
fffrog
Feb 3, 2004 04:10 PM
JDMCivicEF9
19
Sep 6, 2003 11:00 AM
