how noticeable are leaks?
they told me it's an exhaust leak... but everytime i had an exhaust leak, i always knew because you could totally tell right...? so i brought my car to the dealership and they told me i had an air leak somewhere even though it sounds so quiet. even if you had a little hole you would know? i stuck my hands at all the meeting points and no air is felt on my hands...
Modified by the soL that could at 4:53 PM 2/5/2006
depending where the hole is. If its on ur header its probably going to be loud as ****, but if its behind ur cat and resonator, shouldn't be so loud. Just ask them where its at.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS »</TD></TR><TR><TD CLASS="quote">An "air leak" and an exhaust leak is two totally different things.</TD></TR></TABLE>
Totally correct.
An "air leak" is usually something to do with an intake manifold because air is passing through. An exhaust leak is off the exhaust manifold/system.
If you had an air leak you would have a pretty bad idle unless before throttle.
If its an exhaust leak youll have that noice.
Which is it?
Totally correct.
Which is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 »</TD></TR><TR><TD CLASS="quote">depending where the hole is. If its on ur header its probably going to be loud as ****, but if its behind ur cat and resonator, shouldn't be so loud. Just ask them where its at.</TD></TR></TABLE>
i'm straight piped... and i cannot feel any air leaking from behind my test pipe or resonator. it's actually pretty soft.
russian_racer
50
May 2, 2003 12:37 PM
