searched: need lower ball joint help
Old Feb 5, 2006 | 02:49 PM
eg2phosizzle's Avatar
Default searched: need lower ball joint help
okay i understand the process of getting the ball joint out but how do i put a new one in??? would i have to go to a shop to get it pressed in or is there a way i can do it myself without going to the shop and paying for it???any help would be much appreciated thank you
Old Feb 5, 2006 | 04:42 PM
EG2Driver's Avatar
Default Re: searched: need lower ball joint help (eg2phosizzle)
bump for an answer cause mine spins with the castle nut and need to replace.
Old Feb 5, 2006 | 05:11 PM
Luserkid's Avatar
Default Re: searched: need lower ball joint help (deadend9009)
You could rent a tool from autozone. Theres a snap ring on the bottom that needs to be taken out then use the tool and your good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 &raquo;</TD></TR><TR><TD CLASS="quote">bump for an answer cause mine spins with the castle nut and need to replace.</TD></TR></TABLE>
For you, if your LCA is still on then try lifting the disc brake so it puts pressure on the nut and try taking it off slowly.
sky9
12
Jan 8, 2008 01:39 PM
93(Civic)EG6
Sep 1, 2007 08:06 PM
rasinhell
32
Jan 17, 2005 04:57 PM
jaminonyourface
Suspension & Brakes
20
Jan 7, 2005 11:11 AM
87_accord_lx
Jun 22, 2003 08:44 AM
