Accord sidemarkers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowdcn »</TD></TR><TR><TD CLASS="quote">dremel</TD></TR></TABLE>
And do it quick, otherwise the heat will warp the metal surrounding the area you're cutting. Use masking tape to mark off the area you will be cutting on and draw your outline directly onto it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdsquad.net »</TD></TR><TR><TD CLASS="quote">
And do it quick, otherwise the heat will warp the metal surrounding the area you're cutting. Use masking tape to mark off the area you will be cutting on and draw your outline directly onto it.</TD></TR></TABLE>
a lesson learned the hard way
And do it quick, otherwise the heat will warp the metal surrounding the area you're cutting. Use masking tape to mark off the area you will be cutting on and draw your outline directly onto it.</TD></TR></TABLE>a lesson learned the hard way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowdcn »</TD></TR><TR><TD CLASS="quote">a lesson learned the hard way </TD></TR></TABLE>
Yeah, mine started to warp on the first side but I realized it and sped it up a bit. Came out fine tho
Hey, I'm just curious. Do they look like this:
Those are the ones I got for my wagon awhile back and I've seen other CD and CE accords with flat ones. Can anyone enlighten me on which ones I have? I got them on ebay and the seller said they were for the 94-97 accords.
my car. the guy that installed them did it about half an inch too low, ******* tard. I gave him directions and all... but whatever.
free cause he fucked up.
still looks good though.EDIT: damn, my old SD100 really doesn't pick up the detail my new one does. I need to take new pictures when I get my car cleaned up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowdcn »</TD></TR><TR><TD CLASS="quote">those are the cb sidemarkers, the cd accords use flat ones</TD></TR></TABLE>
Please forgive me, what year/model is the CB? Just an "uneducated" guess but I think you're referring to the 90-93 accord, are you not?
and its a good idea to cover the exposed metal after cutting with some touchup paint
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi »</TD></TR><TR><TD CLASS="quote">and its a good idea to cover the exposed metal after cutting with some touchup paint
rust pwnz j00
</TD></TR></TABLE>rust pwnz j00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mangudai »</TD></TR><TR><TD CLASS="quote">So those actually light up when you are signaling for a turn. Nice.</TD></TR></TABLE>
On mine I have it wired up constant on with the parking lights then it blinks when I have the turn signal activated....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 »</TD></TR><TR><TD CLASS="quote">On mine I have it wired up constant on with the parking lights then it blinks when I have the turn signal activated....</TD></TR></TABLE>
Same here.... I <3 My Sidemarkers
