CEL Check - 1996 Civic Hatchback DX (what code is it throwing?)(VID)
Old Feb 5, 2006 | 01:13 PM
pinoyboiwonder's Avatar
Default CEL Check - 1996 Civic Hatchback DX (what code is it throwing?)(VID)
https://home.comcast.net/~effinnwackk/FEB506.MPG
heres a vid..
what code is it throwing??
is it a code 65 - Secondary oxygen sensor heater wire (black wires)
Old Feb 5, 2006 | 01:19 PM
pdiggitydogg's Avatar
Yep, code 65
Old Feb 5, 2006 | 02:59 PM
Default Re: (pdiggitydogg)
any 1 know how to fix it?
Old Feb 5, 2006 | 03:20 PM
Ive never had any luck fixing o2 sensors...I just replace them
http://www.sparkplugs.com get a denso first time fit unit
Old Feb 5, 2006 | 03:22 PM
my friend told me to check the wires at the cat if its loose. i havent done that yet. he also told me to reset the ecu.
Old Feb 5, 2006 | 04:56 PM
bump1
Old Feb 5, 2006 | 05:01 PM
Luserkid's Avatar
Default Re: (pinoyboiwonder)
You reset the code to see if its a dummy code. If its not just replace the o2 sensor, its alot easier then trying to fix them. Did you do anything to the o2 before your code threw?
Old Feb 5, 2006 | 05:28 PM
no i downshifted then redlined it for a bit accidently.. and it threw that code.
Old Feb 5, 2006 | 05:44 PM
EE_Chris's Avatar
Your friend is probably right - get under the car and stop being lazy.
If the wires look good, get a meter, disconnect the O2 from the engine harness and measure between the two black wires. Should be 15-40 ohms. Replace it if it's not.
YaBoiTHiZZ
12
Mar 28, 2012 08:10 PM
scarface50370
Dec 14, 2005 01:21 AM
b18_crx
Oct 27, 2005 05:19 AM
GruvyTune
Nov 4, 2003 07:42 PM
turbotime
Jul 20, 2003 08:11 AM
