residue above header
I have had a DC-S header on for a while and think that I may have a exhaust leak. Its been installed for a year now and there seems to be some carbon buildup on some of the top of the headers where it is bolted to the block. Is this a real problem or can I ignore it for a little bit until I get enough money to replace it? This is an exhaust leak right.
if your car has done alright for a year, a couple more weeks shouldn't hurt. if you don't want to replce the header though, you could just buy a new gasket from honda and that should stop the problem.
Could it be the gasket I have on at the moment it is copper and looks like this, but is not this exact one. Is this better than oem since the header I have already is aftermarket.
use oem exhaust mani gaskets with any header/manifold...what has the carbon? your flange or where the primary pipes meet the flange??? do you run a flex pipe? If your leak is at the primary and flange junction then the lack of a flex pipe would cause cracking...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 »</TD></TR><TR><TD CLASS="quote">what has the carbon? your flange or where the primary pipes meet the flange??? do you run a flex pipe? </TD></TR></TABLE>
Yes there is a flex pipe and the carbon residue is seeping from the block where the headers bolt up to the block.
I have carbon residue above the header flange but I don't think it's b/c of an exhaust leak. how do you know for sure you have one? do you have any pics so I can be sure I understand your problem?
T<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer »</TD></TR><TR><TD CLASS="quote">you can tell if you have a leak by running the car and listening really hard and using your hand to feel for air.</TD></TR></TABLE>
Thanks I'll check it out, but I think it has to do with the product shape at the port holes itself.
b20civicboi
Apr 20, 2006 02:32 AM
