h22a: can to much oil effect vtec pressure switch?
Old Feb 5, 2006 | 09:53 AM
duceducecord's Avatar
Default h22a: can to much oil effect vtec pressure switch?
i have a 93 h22a n i put to much oil in it. it passed the max line and some times my CEL light would pop up CODE 22 which is VTEC PRESSURE switch. was it caused by to much oil?
Old Feb 5, 2006 | 10:58 AM
hondadude's Avatar
Default Re: h22a: can to much oil effect vtec pressure switch? (duceducecord)
I don't think being Slightly over full on the oil will cause the code to come up, The pressure port runs thru the head.
Old Feb 6, 2006 | 12:43 PM
Default Re: h22a: can to much oil effect vtec pressure switch? (hondadude)
for sum reasons when i punch it first gear to like 2nd 3rd..etc.. its fine vtec kiks violently ... but after punching it, i'll hit the freeway n the downshift to like 4th/3rd gear. the vtec seems to be sputtering, sounds like it wants to spit out oil or something. Sumtimes vtec doesnt kick at all, then my CEL light comes on telling me sumthing is wrong wit my VTEC PRESSURE Switch. n i have changed the gasket i even changed out the vtec solinoid with another one i had laying around. it worked for a bit but still the same symtoms im not sure if its my wiring but i'll check that out today
94wip
12
Jun 20, 2024 07:23 PM
Lude-venom
Nov 15, 2008 06:26 PM
d1nki
May 10, 2008 12:23 AM
nelsond
Dec 13, 2006 10:33 AM
cioli
12
Feb 26, 2006 08:31 AM
