any body armor suggestions?
Old Feb 4, 2006 | 09:32 PM
Kelly.'s Avatar
I've quit using this account
Default any body armor suggestions?
since i moved to las vegas, i will be riding alot more.
ill probaly be commuting to work a few days ar week on my bike.
during the winter / early springs i can wear my joe rocket jacket.
but a 10lb leather jacket isnt gonna cut it during the summer
i have seen this armor that icon makes :
i like the idea, but i dont know how much protection it will actually provide.
when i stunt i wear a motorphoria armor suit:
like this:
but this is even to hot for vegas.
does anyone have any suggestions on what i can wear during hot weather months?
i just need something for back and forth to work.
something that will keep me cool and protected. i cant show up to work with no protection, but i cant show up like a sweaty ***** either .
i know joe rocket makes a mesh jacket
like this:
but i am looking for some other suggestions. (because i figure you have to wear the tight so they will be effective ... but i could be wrong)
something more along the body armor lines.
price isnt a big concern.
thanks in advance
Old Feb 5, 2006 | 08:31 AM
marmaladedad's Avatar
Mesh is fine for low-speeds. And anything is better than just skin. With Las Vegas weather, you'll be sweating like a ***** almost anywhere you ride.
Can you bring a change of clothes, instead?
Old Feb 5, 2006 | 09:53 AM
ProjectF4's Avatar
Default Re: (marmaladeboy)
i actually used to race DH Mountain bikes, and here in SC i tend to wear my 661 Pressure Suit... its relativly inexpensive ~100 bucks... and gives you full coverage...
also had spine protector
Old Feb 5, 2006 | 10:16 AM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: (ProjectF4)
Armor won't do **** when the abrasion rips its off of your body.
Go with a high end textile jacket that has armor inserts.
Old Feb 5, 2006 | 10:20 AM
trbo823's Avatar
Textile or Perforated leathers. I have an A* SMX air flow. I used it for SoCal summer weather which is probably cooler than Vegas Summer weather. Id rather sweat a bit than lose my skin.
Old Feb 5, 2006 | 10:25 AM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: (trbo823)
There's a lot of good perforated jackets, leather and textile. I use a Dainese HC-88 textile when it's really hot out and then if it's just ok, I wear a perforated Bora. You can get something a bit less expensive ofcourse. I used to rock a Joe Rocket mesh much like that yellow one but I noticed that it's very loose around the waist and it'd slide up on the torso if I was to ever slide feet 1st. That's no good. Make sure the design of the jacket will keep it in place if you slide. The HC-88 is quite good. Textile and mesh.
Old Feb 5, 2006 | 10:43 AM
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">Mesh is fine for low-speeds. And anything is better than just skin. With Las Vegas weather, you'll be sweating like a ***** almost anywhere you ride.
Can you bring a change of clothes, instead?</TD></TR></TABLE>
im in the military, so bringing all my gear with me is feasiable
thanks for the suggestion.
Old Feb 5, 2006 | 10:44 AM
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectF4 &raquo;</TD></TR><TR><TD CLASS="quote">i actually used to race DH Mountain bikes, and here in SC i tend to wear my 661 Pressure Suit... its relativly inexpensive ~100 bucks... and gives you full coverage...
also had spine protector </TD></TR></TABLE>
this looks like the same thing as my motorphoria suit.
it will protect but it is form fitting, which means ill be a sweaty ***** when i get to work .
thanks though
Old Feb 5, 2006 | 10:45 AM
Kelly.'s Avatar
Default Re: (RebornGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RebornGSR &raquo;</TD></TR><TR><TD CLASS="quote">Armor won't do **** when the abrasion rips its off of your body.
Go with a high end textile jacket that has armor inserts.</TD></TR></TABLE>
are you referring to the icon armor being ripped off during a crash?
any high end textile jacket suggestions
Old Feb 5, 2006 | 10:47 AM
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trbo823 &raquo;</TD></TR><TR><TD CLASS="quote">Textile or Perforated leathers. I have an A* SMX air flow. I used it for SoCal summer weather which is probably cooler than Vegas Summer weather. Id rather sweat a bit than lose my skin.</TD></TR></TABLE>
i agree about the sweat alittel bit rather then lose skin, but i am looking for something just for back and forth to work.
i know i can stillget into a wreck to or from work, but for the most part its slow (20 mph) freeway traffic.
Old Feb 5, 2006 | 10:48 AM
Kelly.'s Avatar
Default Re: (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">There's a lot of good perforated jackets, leather and textile. I use a Dainese HC-88 textile when it's really hot out and then if it's just ok, I wear a perforated Bora. You can get something a bit less expensive ofcourse. I used to rock a Joe Rocket mesh much like that yellow one but I noticed that it's very loose around the waist and it'd slide up on the torso if I was to ever slide feet 1st. That's no good. Make sure the design of the jacket will keep it in place if you slide. The HC-88 is quite good. Textile and mesh.</TD></TR></TABLE>
thanks for the suggestions,
ill look into the HC-88
keep them comin guys
Old Feb 5, 2006 | 11:03 AM
EkEli's Avatar
rebmem roines
Project, What do you wear over top of this?
I could not wear my A-star leather over that so do you just spot a long sleeve t or a textile jacket?
Old Feb 5, 2006 | 11:50 AM
1bar's Avatar
Default Re: (EkEli)
i dont think i could fit any of those options under my jacket, maybe my jacket is too small?? haah oh well
Old Feb 5, 2006 | 11:56 AM
EkEli's Avatar
rebmem roines
Default Re: (1bar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar &raquo;</TD></TR><TR><TD CLASS="quote">i dont think i could fit any of those options under my jacket, maybe my jacket is too small?? haah oh well </TD></TR></TABLE>
I was under impression that leather Jackets are supposed to be tight and snug to fit probably/effective.
I know for a fact that those could not be worn under my jacket although I have protective inserts so if I took them out I may be able to make it work.
Old Feb 5, 2006 | 12:18 PM
20mph on the highway? I've never seen 20mph on the highway ever in Vegas....buncha crazy out-of-towners in a hurry to lose their money....
Old Feb 5, 2006 | 06:50 PM
ProjectF4's Avatar
Default Re: (llewsirc)
it may look the same, but it isn't, it is built for Mountain biking... it is very very breathable, and isn't hot even on the hottest days... form fitting, yes, hot, no
And what do I wear over it? usually nothing, just a cannondale longsleve moisture wicking shirt underneath, and if it's a little chilly, but not cool enough for the jacket, a hoodie.
Old Feb 5, 2006 | 06:57 PM
Kelly.'s Avatar
Default Re: (EkEli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkEli &raquo;</TD></TR><TR><TD CLASS="quote">I was under impression that leather Jackets are supposed to be tight and snug to fit probably/effective.
same reason i think the mesh style jacket wuld be to hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">20mph on the highway? I've never seen 20mph on the highway ever in Vegas....buncha crazy out-of-towners in a hurry to lose their money.... </TD></TR></TABLE>
hop on the 95 at rainbow rd at 7am and try to get to craig rd and I-15
14 ,iles takes me 40 mins easily
Old Feb 5, 2006 | 11:38 PM
big pete's Avatar
Mesh will melt faster if you go down in LV heat
as someone said, dainese makes some great perforated jackets. I have one (zag pelle). Wore it in 85 degree weather and its not that bad (only wearing a tshirt underneath). It only sucks if you're sitting in traffic....once you're moving its great. For better cooling, wear some underarmor under the perforated jacket.
I've worn my perforated dainese leather suit w/ underarmor in 95-105 degree weather (at Thunderhill Raceway) and its fairly comfy once you get moving
Old Feb 6, 2006 | 06:58 AM
Kelly.'s Avatar
great reply
Thanks !!
Flashmn
Other Make Vehicles
Feb 13, 2010 06:34 AM
LSintegra
Honda Motorcycles
11
Oct 21, 2008 05:30 PM
thehondaguru
Honda Motorcycles
26
Jul 15, 2006 08:56 AM
fluke702
Honda Motorcycles
36
Mar 8, 2005 07:53 AM
dustin
Honda Motorcycles
39
Aug 18, 2003 11:58 AM
