NEED HELP!!!! replacing wheel studs
Old Feb 4, 2006 | 09:12 PM
sinesterxone's Avatar
Default NEED HELP!!!! replacing wheel studs
I broke 2 of my wheel studs on my 00 civic EX. And just to save some time, I would like to know the correct way of replacing the broken ones. Both are on the front driver side if that matters. What all needs to be disassembled? It doesn't look like it'll be too hard to do, but I'd rather be safe then sorry. Please help. Thanks.
Old Feb 4, 2006 | 09:42 PM
s13browe's Avatar
Default Re: NEED HELP!!!! replacing wheel studs (sinesterxone)
hard: if Im not mistaken you have to take off the caliper, rotor, axle nut than get a slide hammer and hook it up to the remaining studs slide out the hub bearing assembly put in vice knock out studs press new studs in than put assembly back in impact axle nut back on to re press bearing assembly back in till nut stops moving reinstall rotor and caliper and wheel, test drive for roaring noise if noisy bearing not pressed in all the way tighten axle nut more...
Old Feb 4, 2006 | 09:43 PM
s13browe's Avatar
Default Re: NEED HELP!!!! replacing wheel studs (s13browe)
rears are much easier next time break those...
Old Feb 7, 2006 | 01:23 PM
THANKS
Old Feb 7, 2006 | 01:29 PM
ralphie14's Avatar
Have you tried searching? I know there was a good write up on doing this on an EK a few months back I have the link at home but not here at work sorry.
Old Feb 7, 2006 | 02:35 PM
BauleyCivic's Avatar
Risky Business
Default Re: NEED HELP!!!! replacing wheel studs (ralphie14)
https://honda-tech.com/zerothread?id=907985
Old Feb 13, 2006 | 05:17 AM
ralphie14's Avatar
Default Re: NEED HELP!!!! replacing wheel studs (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=907985</TD></TR></TABLE>
That would be the one
Old Feb 13, 2006 | 11:38 AM
ezekiel1059's Avatar
that would actually be a prety damn great one! ive been searching for a DIY like that, perfect.. now if there is one for the rear drums, 00 civic ex?
Old Feb 13, 2006 | 12:35 PM
kaiba's Avatar
Default Re: (ezekiel1059)
Is there any way to take out the hub while the entire spindle assembly is not on the car.
Old Apr 25, 2006 | 12:33 AM
Touch's Avatar
Default Re: (kaiba)
back from the dead... yes is there anyway?
cheifncomer
Nov 21, 2008 04:15 PM
ekeddie
Suspension & Brakes
10
Oct 14, 2007 12:28 PM
HCivExoo
Mar 19, 2005 09:05 PM
dumppp gook
Mar 15, 2004 12:12 PM
ironcheftony
Sep 15, 2003 07:45 PM
