DIY: 5th gen JDM city light. MY WRITE UP, pic walkthrough.
Old Feb 4, 2006 | 05:41 PM
Daishi's Avatar
Default DIY: 5th gen JDM city light. MY WRITE UP, pic walkthrough.
I am dumb, and suck when it comes to electronics and wiring, but this was pretty easy
It was all stock USDM corner light + headlight wiring, I bought the JDM headlights + clear corners from Password:JDM with the wiring kit, took some pics, so yeah.
I know it's been done a million time, but I made my own just in case. So yeah... enjoy.
^^^ beforehand. I lost a corner on the interstate, it ripped out part of the headlight mounting bracket, so I was like "expletive it" and just ordered the whole new set up.
^^^ Word.
^^^ Yarrrrrr
^^^ Stock corner light connection. 3 wires. JDM has 2. Reason=
Red = power at all times. Receives power when you switch the lights to stage 1 and 2, thus why stock corners come on with first click, and stay on while headlights are one. JDM headlights, the corners only BLINK. They don't stay on, so the JDM cluster has the red wire go to CITY LIGHT and not corner.
Green = blinker. Gives power when you hit the turn signals, warning lights. JDM connection has this only to corner and to sidemarkers. They only BLINK, they dont stay on with lights.
Black = Ground.
When my corner light riped out, it took the part that holds bulbs with it... so I had 2 choices. Put in JDM one on driver side and just splice up the USDM one on passenger... or swap both.
I decided to just snip all the wires and wire everything new in place.
^^^ JDM connection (in hand, brown) next to the USDM one. 2 wires compared to 3. My corner lights CAME WITH the plastic part that holds bulb plugged into the back, and the male end of the connection with wires snipped... so I had everything I needed to put it into place.
^^^ JDM connections. Little different than USDM. You can't just plug the 2 together. The USDM 3 wire male connectin WILL NOT FIT into the JDM unit.
^^^ Got some tools out.
^^^ Cut the connection out, had to rearrange the wires. Kept the green/black on the corner light side, pull the red one through and move to behind the headlight.
^^^ I suck at sodering. Just twisted them together, and did this. Then wrapped each individually with a load of electrical tape, and then even more. LOL.
^^^ All 3 connections wired up. The JDM corner light connection has the green/black(ground) The city light is to the red, and the black runs through over to the same ground as the corner.
I don't know if this is technically 100% safe in electrical terms.. but yeah I suck so I did it.
^^^ Make sure you're not a dumbass and know what goes where. City light, headlight (this was same as USDM so I didn't touch) and the corner light.
^^^ Bolt those bitches up and make sure everything is in tight. I make sure there was no moisture in any of the lights before sealing them up. If you're super **** like me, mess with the headlight bolts and adjust to make sure both beams of headlights aim the same. I did this against inside of my garage door.
^^^ first click = city lights only, 2nd = Headlights. My corners work fine, but ONLY BLINK with turn signal. not on at all otherwise.
I like it. I have the sidemarkers too, and they are the same connection as the city lights, so I'm going to do them soon. I used the Password:JDM connections in the city lights, so I have the stock ones from the headlights that I can modify, add like 2 feet of wire and tap them into the corner lights.
So yeah I'll do that soon, but yeah :D
<FONT SIZE="20">BIG NOTE... NOT TO EVERYONE BUT SOME</FONT>
Not in the main context of this DIY, but possibly... I found out the JDM headlight housing is a little larger than the USDM one, and I could NOT fit the headlight into place because of my hood pins.
I ended up marking them off on top and bottom with marker, taking completely off and hacksawed the bottom off and remounted to give the extra clearance for headlights.
Yep.
Old Feb 4, 2006 | 05:48 PM
Scotty Dosent Know's Avatar
Looks great! nice write up
Old Feb 4, 2006 | 07:12 PM
orangina's Avatar
Default Re: DIY: 5th gen JDM city light. MY WRITE UP, pic walkthrough. (Daishi)
good stuff man!
Old Feb 4, 2006 | 07:20 PM
bs-inc's Avatar
Default Re: DIY: 5th gen JDM city light. MY WRITE UP, pic walkthrough. (orangina)
Tyte, I gotta wire up my jdm headlights and sidemarkers.
Old Feb 5, 2006 | 12:09 AM
carlton585's Avatar
WORD.
Old Feb 5, 2006 | 08:38 AM
RedEK9's Avatar
Default Re: (carlton585)
Looks Good!
Old Feb 5, 2006 | 11:28 AM
Daishi's Avatar
morning bump, just to see if anyone else wantsto read it :D
Old Feb 5, 2006 | 08:17 PM
carlton585's Avatar
Default Re: (Daishi)
It's a little bit different than EK, but that's 100% nice for 5th gens :D
Old Feb 5, 2006 | 08:20 PM
.:Swig:.'s Avatar
interesting, but nice
Old Feb 5, 2006 | 08:25 PM
JDM-EJ1's Avatar
Default Re: (ECKO1980)
I fit my hood pins just fine with my JDM headlights.
Old Dec 24, 2006 | 10:22 AM
spuddo01's Avatar
Default Re: (JDM-EJ1)
Old Dec 24, 2006 | 10:55 AM
bart2546's Avatar
Default Re: (spuddo01)
I like it, it's in
Old Dec 24, 2006 | 04:56 PM
EK tommy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spuddo01 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Dec 24, 2006 | 05:07 PM
97spooncivic's Avatar
Default Re: (EK tommy)
for the great writeup
just learn how to solder, haha
Old Dec 24, 2006 | 05:08 PM
NMZ's Avatar
NMZ
now get some wheels
Cboy1-EG6
11
May 5, 2005 01:08 PM
stRodda
Apr 24, 2004 05:27 PM
jerry5150
Apr 16, 2004 10:08 AM
.paul
Mar 23, 2002 09:42 PM
