shift problem b16a2
Old Mar 25, 2002 | 09:53 AM
kamciu80@aol.com's Avatar
Default shift problem b16a2
i jsut got a b16a2 in a 94 civic coupe .its was an auto to 5spd swap and now i have shifting problems. the gears go in really rough when driving but at idle its fine. i thought it might be the bushing or motor mounts? do u guys know which shift linkage i should use and how can i tell the difference between a civic linkge and an integra linkage? thanx
Old Mar 25, 2002 | 01:03 PM
DR. ON POINT's Avatar
Banned
Default Re: shift problem b16a2 (kamciu80@aol.com)
u should have used the integra shift linkage........go to acura they are 100 bucks
Old Mar 25, 2002 | 03:04 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: shift problem b16a2 (On Point EK)
You can use the Teg linkage like On Point said, or you can use 99-00 Civic Si linkage too.
Also don't forget to properly bleed the clutch hydrolics. Even if the linkage is perfect, air in the clutch lines will cause shitty clutch response.
TylerB
Mar 24, 2010 12:42 PM
shortbuss90
May 20, 2009 09:56 AM
9three4drintegra
Aug 14, 2005 09:21 AM
adobospoon
Dec 27, 2004 10:49 PM
2muchPSI
Nov 7, 2002 07:01 PM
