rpm at idle?
Old Feb 4, 2006 | 02:32 PM
musTerdh22eg's Avatar
Default rpm at idle?
whats the normal rpm at idle for a b16a2?
Old Feb 4, 2006 | 03:47 PM
Default Re: rpm at idle? (myb16civic)
bump for quick answer
Old Feb 4, 2006 | 04:15 PM
Out of every
i dont think it matters on the motor.. but i have a gsr and it idles at 600
Old Feb 4, 2006 | 04:24 PM
Default Re: rpm at idle? (e gee two)
i was asking cause i idle at like 900 at start up but when i start driving idle jumps to like 1300, and i get a cel after about 5 min of driving. what could this be?
Old Feb 4, 2006 | 04:42 PM
Dirtfall's Avatar
i think it depends on the mods you have. Mine doesnt like to idle at 600 it almost dies. 800-900 is perfect for my car. But i have ctr pistons and cams in my b16. Tell me what the code your throwing is and i could probably help you better. Is your car mostly stock? My guess as of right now is you might want to see if your IACV is bad.
Old Feb 4, 2006 | 04:49 PM
Default Re: rpm at idle? (Dirtfall)
i have simple bolt-ons: intake, cat-back, clutch and type-r ecu
i checked under the dash and i didnt see the port for obd2, am i just blind or are b16a2 swaps not obd2
Old Feb 4, 2006 | 04:59 PM
Dirtfall's Avatar
they are OBD2 unless you convert it to OBD1
Old Feb 4, 2006 | 05:05 PM
in another thread it said that in the 96s its up under the corner of the glove box
im not at home so i cant look but is that where it is?
Old Feb 4, 2006 | 05:23 PM
Dirtfall's Avatar
Im not sure i have a 94 cx with b16a2 in it. my ecu is under the carpet on the passengerside. right under the glove box. But yea definatly check around that area around the glove box. If you dont know how to check an engine code go here https://honda-tech.com/zerothread?id=1171263.
svsummerwind
Sep 2, 2017 06:53 AM
300whpej
May 20, 2010 10:25 PM
catdaddy77
Feb 16, 2009 06:03 AM
pork
Sep 24, 2007 09:46 AM
