95 civc fuse panel. headlights drain battery
My daughter has lost her cover to the inside fuse panel. I cannot tell what fuses she is missing or may need.
She is forever leaving her headlights on and Draining the battery. I know the simple answer is to leave her stranded once or twice and maybe she won't forget.
Does she have a chime to remind her headlights are on with the car turned off?
If not, with the fuse panel or schemo I can add a relay that will turn off lights when the key is off.
thanks in advance.
tom
thanks in advance.
tom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjd92accord »</TD></TR><TR><TD CLASS="quote">Does she have a chime to remind her headlights are on with the car turned off?</TD></TR></TABLE>there is a chime that works with some head units, but its really easy to ignore and i forget half the time.
there are a few diagrams in these threads... but im not sure which you need. i think it varies slightly from car to car, but here they are anyway:
https://honda-tech.com/zerothread?id=1446403
https://honda-tech.com/zerothread?id=1443774
https://honda-tech.com/zerothread?id=1499682
there are a bunch of others if you search for 'fuse box', as i have mentioned in your other thread
you could always make her join AAA and have her call them for a jump every time
Modified by thisisntjared at 11:44 PM 2/4/2006
jeanine25512
Honda Civic (2001 - 2005)
Jan 13, 2014 07:13 PM
