Lighting HID/Xenon kits, Retrofits and Associated Topics
s2k, headlights not working.. OEM stuff
Old Feb 11, 2008 | 10:14 PM
dagle's Avatar
Default s2k, headlights not working.. OEM stuff
so I recently mixed up the battery terminals and blew the battery fuse.. after replacing the battery fuse, everything works now except for the headlights and the radio.. could the mixed up terminals damage my ballast or blow the bulbs? Im replacing the lighting relays tomorrow to make sure.. please help
Old Feb 12, 2008 | 12:52 PM
prelude1897's Avatar
Default Re: s2k, headlights not working.. OEM stuff (dagle)
check the fuses for the headlights and the radio. They're most likely under the hood
Old Feb 12, 2008 | 06:49 PM
dagle's Avatar
Default Re: s2k, headlights not working.. OEM stuff (prelude1897)
oh forgot to mention, i did check the fuses and tested them w/ known-good fuses.. thanks brian.
Old Feb 13, 2008 | 04:07 PM
a way I always test my ballast is to hook them straight up to the battery. If they work hooking straight up to the battery, then they're still good. I believe there's a fuse inside the car for the radio as well. If all checks out correctly, may just have a messed up relay
Old Feb 14, 2008 | 09:28 PM
dagle's Avatar
yeah i checked the radio fuses.. i really do hope its as simple as a relay though got a lot of car expenses right now.. don't want to put my other stuff on hold
HotImportNightHonda
14
Oct 10, 2024 12:34 PM
jeanine25512
Honda Civic (2001 - 2005)
Jan 13, 2014 07:13 PM
FastHatch90
Apr 3, 2006 07:47 PM
tjd92accord
Feb 4, 2006 07:38 PM
c for sea
21
Aug 12, 2005 06:38 PM
