VAFC Hack Question - H22A @ 5-6psi
Old Feb 4, 2006 | 02:05 PM
UK_prelude VTEC's Avatar
Default VAFC Hack Question - H22A @ 5-6psi
OK, after much searching and reading, I understand how the VAFC hack works, how to set it up and it's drawbacks. My question is - you work out the correction to dial in based on the size difference between your stock injectors and your new ones, right?
So, on a 95 H22A (stock injector size 345cc), running, say, 450cc injectors, the correction should be (345/450)-1= -23%. Right?
So why does everybody seem to run corrections in the -35 to -40 range?? or is that just on B/D16s with smaller stock injectors?
My other questions are:
Does anybody know how to work out the relationship between MAP voltage, how the VAFC corrects it per % of correction, so I can work out the limits of this setup compared to max boost pressure? (eg at 5 psi, x % of correction represents 3.2 Volts MAP voltage (or whatever the max is before ECU throws a CEL)
How much timing advance would you get with corrections in the -25 to -20 range? I'm presuming less severe than at -40ish?
Yes I KNOW there is a fantastic thread archived about the VAFC hack, but the pics of timing / fuel maps on it are down and the explanation doesn't really make much sense without them!!
Old Feb 4, 2006 | 04:38 PM
Default Re: VAFC Hack Question - H22A @ 5-6psi (UK_prelude VTEC)
Anyone?
Old Feb 5, 2006 | 05:59 AM
Bump
Griffin@Camtech
Feb 6, 2004 10:31 AM
RudeLude
Jan 5, 2004 03:15 PM
1.8T_EG
Dec 9, 2003 09:11 PM
RudeLude
Nov 24, 2003 06:50 AM
1.8T_EG
Sep 16, 2002 12:22 PM
