Cam Timing
Old Feb 4, 2006 | 10:18 AM
Hemi_powered's Avatar
Default Cam Timing
Is my cam timing off if I advance my distributor all the way and can just barely pass the crosshair on the flywheel and not make it to the correct timing marks?
Old Feb 4, 2006 | 10:55 AM
Hawkze_2.3's Avatar
Default Re: Cam Timing (Hemi_powered)
It's not a Hemi V8 , to check cam timing you need to line up the marks on the cam gears and the flywheel, no need for a timing gun or light.
Old Feb 4, 2006 | 12:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hemi_powered &raquo;</TD></TR><TR><TD CLASS="quote">Is my cam timing off if I advance my distributor all the way and can just barely pass the crosshair on the flywheel and not make it to the correct timing marks?</TD></TR></TABLE>
having the deuce in a small car makes me delusional sometimes ..i'm just double checking if the intake cam is off then the ignition timing would be off, since its connected to the distributor. I have my distributor turned toward the firewall all the way and the the timing mark for 15btdc is a quarter inch away with no more room for adjusting..the arrows were both pointing up when i did the timing belt..but i didn't check to see if the horizontal lines matched up...TIA
Old Feb 4, 2006 | 12:46 PM
Rosko's Avatar
yeah id say you might be off, distributor should easily land in the middle of its adjustment.
johnwohl
Apr 1, 2008 07:29 PM
has-t
Jul 1, 2003 09:58 AM
Mr.Integra
May 22, 2003 12:41 AM
Alias
Jan 28, 2003 06:56 PM
Jockobo
Jan 23, 2003 03:48 PM
