Hondata IM gasket sealing Question
Old Feb 4, 2006 | 07:05 AM
captainjdog's Avatar
Default Hondata IM gasket sealing Question
I got my Hondata IM gasket, *Copy* And its just a plastic 1/4" plastic gasket shape thing. My question is do I need to put normal gaskets on both sides of this thing? Or does the plastic seal? Maybe add some high temp goop for good measure.
Thanks,
Captain
Old Feb 4, 2006 | 07:17 AM
ladysman's Avatar
Default Re: Hondata IM gasket sealing Question (captainjdog)
This is a "true" hondata gasket but you get the idea. Whether there is a difference, I have no idea.
Old Feb 4, 2006 | 07:30 AM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by captainjdog &raquo;</TD></TR><TR><TD CLASS="quote">I got my Hondata IM gasket, *Copy* And its just a plastic 1/4" plastic gasket shape thing. My question is do I need to put normal gaskets on both sides of this thing? Or does the plastic seal? Maybe add some high temp goop for good measure.
Thanks,
Captain</TD></TR></TABLE>
to answer your question. No you dont have to put any gaskets or "goop" on it.... just slap it on and tighten it down and it will work fine.....
Old Feb 4, 2006 | 06:07 PM
Default Re: Hondata IM gasket sealing Question (BoostedEG6)
Ok thanks, Well if it leaks i'll know right away, anyway. Just wasn't sure how it would hold up to 25psi.
Old Feb 4, 2006 | 09:40 PM
StockBlockRob's Avatar
plenty of people have used them passed 30 psi making over 600 whp
Old Feb 5, 2006 | 07:09 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by captainjdog &raquo;</TD></TR><TR><TD CLASS="quote">Ok thanks, Well if it leaks i'll know right away, anyway. Just wasn't sure how it would hold up to 25psi.</TD></TR></TABLE>
If installed correctly, it will no problem. Make sure both surfaces are perfectly clean. Good luck.
Old Feb 5, 2006 | 07:44 AM
TURBODC4TEG's Avatar
Default Re: Hondata IM gasket sealing Question (ladysman)
just tighten the bolts in a star pattern and you will be fine
Old Feb 5, 2006 | 08:06 AM
iBrandon's Avatar
Default Re: Hondata IM gasket sealing Question (TURBODC4TEG)
use lock washers and nylon washers....
M2B4
Oct 13, 2007 06:42 PM
GSR4U2NV
11
May 22, 2005 08:04 PM
AzG35
Jul 23, 2004 09:04 AM
kwik92hb
Jan 29, 2004 09:05 AM
GQ 05YellowEVO8
Dec 17, 2002 06:37 PM
