Hondata IM gasket sealing Question
I got my Hondata IM gasket, *Copy* And its just a plastic 1/4" plastic gasket shape thing. My question is do I need to put normal gaskets on both sides of this thing? Or does the plastic seal? Maybe add some high temp goop for good measure.
Thanks,
Captain
Thanks,
Captain
Re: Hondata IM gasket sealing Question (captainjdog)
This is a "true" hondata gasket but you get the idea. Whether there is a difference, I have no idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by captainjdog »</TD></TR><TR><TD CLASS="quote">I got my Hondata IM gasket, *Copy* And its just a plastic 1/4" plastic gasket shape thing. My question is do I need to put normal gaskets on both sides of this thing? Or does the plastic seal? Maybe add some high temp goop for good measure.
Thanks,
Captain</TD></TR></TABLE>
to answer your question. No you dont have to put any gaskets or "goop" on it.... just slap it on and tighten it down and it will work fine.....
Thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by captainjdog »</TD></TR><TR><TD CLASS="quote">Ok thanks, Well if it leaks i'll know right away, anyway. Just wasn't sure how it would hold up to 25psi.</TD></TR></TABLE>
If installed correctly, it will no problem. Make sure both surfaces are perfectly clean. Good luck.
AzG35
07-23-2004 09:04 AM
