type r distributor cap and rotor
Old Feb 4, 2006 | 07:03 AM
psegs80's Avatar
Default type r distributor cap and rotor
My cap and rotor are from my jdm 98 b18c5 distributor is done, can I use a us b18c5 cap and rotor?????
Old Feb 4, 2006 | 08:04 AM
psegs80's Avatar
Default Re: type r distributor cap and rotor (psegs80)
I'm sure someone here has had to change a jdm cap and rotor, just need to know if you can use the U.S version?
Thnaks
Old Feb 4, 2006 | 11:00 AM
CW-ITR's Avatar
I have not change one. But, I think they are interchangeble as long as the OBD versions are the same. Call up one of those JDM importers and ask. I'm sure they ough to know.
Old Feb 4, 2006 | 11:22 AM
Chris F's Avatar
Default Re: (CW-ITR)
PM Wai.. I'm sure he knows.
Old Feb 4, 2006 | 11:46 AM
erikiksaz1's Avatar
Default Re: (Chris F)
Yes, it'll work. I just replaced mine 2 months before I found out my bearings were on their way out.
Interested in a 2 month old cap and rotor?
Old Feb 4, 2006 | 12:08 PM
HAHAV8's Avatar
Default Re: (erikiksaz1)
My R was imported from Japan, and the whole distributor went, I bought one off a USDM Type R and it worked fine. They will interchange.
Old Feb 4, 2006 | 01:22 PM
SkankyEJ7's Avatar
Default Re: (HRi EvolutionIX)
the gs-r one are even the same im pretty sure the all like td84u or like td86u or td 87u or something
Old Feb 4, 2006 | 07:35 PM
SlapSmak's Avatar
Default Re: (98ekhx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ekhx &raquo;</TD></TR><TR><TD CLASS="quote">the gs-r one are even the same im pretty sure the all like td84u or like td86u or td 87u or something</TD></TR></TABLE>
no, the GSR Cap will not fit an R distributor, it is 2 mm too small...
When the screw came out of my rotor and went through the R's cap I tried to use my GSR's cap, but no go...
spaceman
Aug 30, 2016 02:43 PM
tunedek
Apr 14, 2007 03:03 PM
Mike95lude
Oct 27, 2003 01:02 PM
boosted1993fd
Jun 3, 2002 11:39 PM
