Corrosion???
Old Feb 4, 2006 | 06:56 AM
NewfieAccordEXR's Avatar
Default Corrosion???
My battery terminals keep getting A LOT of corrosion building up on them. I sand if off but it just keeps coming back fast, any idea on why it would be doing this and does it matter?
Old Feb 4, 2006 | 07:05 AM
Stew Pidasso's Avatar
Default Re: Corrosion??? (NewfieAccordEXR)
Use a battery terminal sealer such as Castle's Long Life.
Old Feb 4, 2006 | 07:07 AM
P_Adams's Avatar
Corrosion on Battery terminals indicates the presense of Sulfuric Acid. It causes the pitted of steel fittings, the blue crystals from any copper and also blisters the wire insulation and can cause a condition called black wire (attacks the conductor).
Only two things can contribute to this.
The Battery leaks around the terminals.
The Battery is being overcharged, and it builds up internal pressure.
You might try a coating of either wheel bearing or white lithium grease once you again clean them.
P
fleabag
Jul 2, 2012 09:39 AM
CrazyModGSR
Audio / Security / Video
Jun 16, 2004 04:11 PM
Keith P
Mar 22, 2004 12:59 AM
94TealGSR
Nov 8, 2002 11:36 AM
