d16 internals swap?
Old Feb 3, 2006 | 10:00 PM
Ahks's Avatar
Default d16 internals swap?
i was under the impression that all d16 internals were interchangable
for instance buying a donor block and putting the a1 crank/rods/pistons in it
EDIT: I can't for the life of me remember why i posted this in here instead of the EG forums oh well...
Modified by Ahks at 3:00 AM 2/4/2006
Old Feb 4, 2006 | 06:41 PM
SVOboy's Avatar
Bump
Old Feb 5, 2006 | 10:53 AM
Ahks's Avatar
Default Re: (SVOboy)
/\ /\ like he said /\ /\
Old Feb 5, 2006 | 11:01 AM
jlicrx's Avatar
Default Re: (Ahks)
not sure of your question, but yes D16A1 pistons and rods will work in D-series block - the crankshaft may or may not work, depending on what size the front snout is - you would need to make sure that the timing gear that goes on the crank will fit - you can't use the A1 crank gear on a SOHC engine - what year is the D16A1? does it have domed pistons?
Old Feb 5, 2006 | 12:11 PM
Ahks's Avatar
Default Re: (jlicrx)
situation is this...
i'm looking at buying the d16a1 pistons/rods and possibly crank but i have a 91 crx so the a1 won't bolt in cause it's the one from the older tegs but i really like the CR with the A1 and head i'm looking at (D15B VTEC JDM) but since the block won't fit in my car without fabrication i want to use a doner y8 or z6 or ?? bare block and use the a1 internals to get my desired result
can i do this?
Old Feb 5, 2006 | 12:29 PM
jlicrx's Avatar
Default Re: (Ahks)
yes - just watch crankshafts - there are 2 different ones on the A1 - also, if you happen to be planning to run a JDM ZC transmission, you need to watch which block you get as not all will permit bolting on of the intermediate shaft - i was asking what year the A1 is because the 86-87 did not have the domed pistons
Old Feb 5, 2006 | 12:38 PM
Ahks's Avatar
finally the answeres i was looking for
thanks a ton dude
jdmeg6fan
Engine Machining & Assembly
Dec 29, 2016 09:51 PM
Matt91
12
Dec 12, 2009 08:27 PM
88crx-si
Jun 12, 2006 04:49 PM
GSRacer
Jan 25, 2002 02:09 PM
