my car wont start!!!!! i need help desperately!!!!!!
Old Feb 3, 2006 | 03:50 PM
hurraquio's Avatar
Default my car wont start!!!!! i need help desperately!!!!!!
Ok heres what happened i this morning i took out the thermostat and when i put it back on and reconnected everything. the car just cranks and it wont start.
1 yes i did check the posts on the main relay thing but the problem is that i dont hear it click.
2 i dont hear the fuel pump and when i crank it, i dont smell fuel either.
3 and the main one... usually on all cars ive drove when youre about to start your engine, and flip the swich to RUN the yellow check engine light usually comes on then goes off in a couple of seconds. but now it doesnt even come on. any of you guys that has had this problem please help me i neeed it!!!
thank you
Old Feb 3, 2006 | 05:08 PM
Azndude1983's Avatar
Default Re: my car wont start!!!!! i need help desperately!!!!!! (hurraquio)
I've never had any problem like that before. I've done installing turbos on cars and sometime we forget to Reconnect the Battery Back. You might want to check your Battery or check the Battery Wires. Also check the Fuse to see any of them are burnt (Driver Side, Passenger Side and the one under the hood).
Old Feb 3, 2006 | 06:07 PM
YeuEmMaiMai's Avatar
check to see if your ecu is getting power.
Old Feb 4, 2006 | 05:12 AM
hurraquio's Avatar
Default Re: my car wont start!!!!! i need help desperately!!!!!! (YeuEmMaiMai)
yeah i think it is one of the wires but i dont know where the ECU is. ive tried looking for it under the passengers side front carpet but it wasnt there.
Old Feb 4, 2006 | 07:48 AM
hondaguy6513's Avatar
If the check engine light isn't coming on during bulb check, your ECU is not getting power, or ground. Check ALL grounds under the hood, around where you were working.
Old Feb 4, 2006 | 10:26 AM
hondadude's Avatar
put the ground back on to the T-stat housing
Check around to see if you can figure out what YEAR and MODEL you have?
Old Feb 4, 2006 | 05:49 PM
hurraquio's Avatar
Default Re: my car wont start!!!!! i need help desperately!!!!!! (hondadude)
the ground thats it. i think. my model is a 1991 honda accord DX or EX but im 90% sure its a DX.
heres what ive found today.
still when i set the ignition to II the batery light the oil light and the seatbelt light come on. but not the yellow check engine light. i took out the carpet and it turns out that those idiots put the ECU Backwards so i cant see the blinking light. or if its like you guys say that its because the ecu is not getting power cause of the grounding then the light wouldnt come on. i will try to look for grounds right now. and if this trial membership ends and becomes full i will post the results but im gonna start around the thermostat area.
thank you very much for your help.
Old Feb 4, 2006 | 07:34 PM
hurraquio's Avatar
Default Re: my car wont start!!!!! i need help desperately!!!!!! (hondaguy6513)
hondaguy6513 and hondadude
My thanks go out to you guys!!!!!!!!! if only i would know your real names or nicknames and i would invent a pitch after you guys. you saved my date toninght and my ball game tommorow morning. thank you very much guys!!!!!!!! i was about to de wire my whole car if it werent for you guys!!!!!! thanks.
smbignick
Aug 18, 2013 01:47 PM
iamtehwinnar
Apr 24, 2007 05:22 PM
stubk20
Oct 18, 2005 06:44 AM
jdmDAsix
Aug 10, 2005 01:01 PM
crexer
Aug 30, 2004 07:16 PM
