Would having your wastegate open or close during daily driving which would overspin the turbo?
Old Feb 3, 2006 | 03:34 PM
JUST2SPOOL's Avatar
I AM A SCAMMER, DO NOT BUY ANYTHING FROM ME.
Default Would having your wastegate open or close during daily driving which would overspin the turbo?
Like the title says can some one please explain to me what makes a turbo over spin or over spin thanks you
Old Feb 3, 2006 | 03:54 PM
raene's Avatar
Default Re: Would having your wastegate open or close during daily driving which would overspin the turbo? (
You won't overspin the turbo during regular driving unless you go WOT, basically.
You will overspin the turbo if the compressor outlet is disconnected from anything.
Old Feb 3, 2006 | 09:26 PM
unclepowers's Avatar
WTF
Old Feb 3, 2006 | 10:13 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
You will overspin the turbo if the compressor outlet is disconnected from anything. </TD></TR></TABLE>
x2. If you have the wastegate always open, you just won't make any boost. The only time you overspin if you disconnect the charge pipe from your car.
Old Feb 3, 2006 | 10:16 PM
fastrunner's Avatar
I call BS, That crap:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">You won't overspin the turbo during regular driving unless you go WOT, basically. </TD></TR></TABLE>
Depends on the efficiency of the turbo If you are using some puny lil turbo then yes it will run out of breathe and you will spin it and nothing will happen.
Old Feb 4, 2006 | 07:28 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner &raquo;</TD></TR><TR><TD CLASS="quote">I call BS, That crap depends on the efficiency of the turbo If you are using some puny lil turbo then yes it will run out of breathe and you will spin it and nothing will happen.</TD></TR></TABLE>
Ya, 'cause large turbos are more efficient when connected to nothing... look at the frigging question, it's about turbos IN GENERAL.
RACEPAK
Jan 22, 2008 05:50 PM
greygoose
Dec 30, 2007 05:23 PM
dr_latino999
Sep 30, 2007 07:21 PM
JDM BB2
Jul 15, 2004 04:11 PM
grngsr01
Nov 5, 2003 05:23 PM
