mysterious limp mode
Old Feb 3, 2006 | 11:10 AM
. M i c h a e l's Avatar
dotmichael to you
Default mysterious limp mode
just went out to run some errands, i filled up on gas went to leave and noticed the car was revving, intake screaming..but i wasnt moving. i thought it was my clutch finally slipping (it grabs high) so thought nothing of it until i noticed it was also running like ****.
then it wouldnt rev past 4,000. i'm like okay...limp mode. so while in the two minutes it took my car to get to 40 mph i checked for codes. nothing. i finally got home and checked again..nothing. no CEL, no codes.
i drove a few minutes this morning with no problems and drove to the gas station problem free. it happened after i filled up.
i DID run the car bone dry before I filled up on hess..also yesterday I changed my fuel filter and o2 sensor
I'm going to go pull the ECU fuse and see if that fixes it..but I'd still like to know why it happened.
Old Feb 3, 2006 | 12:08 PM
dotmichael to you
Default Re: mysterious limp mode (. M i c h a e l)
ECU fuse was pulled a good half hour..car revs to almost 5,000 now..but once its past 4,000 it sounds like something is tapping or rubbing. doesnt sound like a valve tap though.
took it about 500 feet down the street, and same power loss..but i hear something almost like a metallic whoosing ( i know this makes zero sense)
i dont know what to do. still not CEL, still no codes.
Old Feb 3, 2006 | 12:19 PM
tsdenny's Avatar
try switching the ecu itself
something could be wrong with oyur ecu
Old Feb 3, 2006 | 12:37 PM
dotmichael to you
Default Re: mysterious limp mode (void_accord)
ecu going out of nowhere?
Old Feb 3, 2006 | 01:23 PM
purps's Avatar
Try replacing your Idle Air Control valve, it won't throw a code when bad.
Old Feb 3, 2006 | 01:36 PM
dotmichael to you
Default Re: mysterious limp mode (purps)
first off...IACV is a code 14 if i'm not mistaken..and what would that have to do with going into limp mode?
Old Feb 3, 2006 | 01:53 PM
tsdenny's Avatar
my ecu wnet into limp mode
i switched ecu with my friends and it ran fine
then his car went into limp mode
i just brought a new ecu no problem since
Old Feb 3, 2006 | 02:10 PM
96ls's Avatar
sell this car!!!!
j/k but damn mike, when are the problems gonna stop?
Old Feb 3, 2006 | 03:31 PM
Sottilde's Avatar
I've heard of problems like this from running bone dry. Try daily driving the car for a few days and seeing what happens at the end of the week.
When you run your car to the bone, allegedly it picks up all of the crap at the bottom of the gas tank and can mess things up for a few days. Make sure you fill it up when it hits E.
Old Feb 3, 2006 | 03:41 PM
dotmichael to you
Default Re: (Sottilde)
there's no way in hell that i'll drive the car anywhere besides down the street like this. there is hardly any power at all.
i've ran cars dry before and while they might act like **** because of the crap at the bottom..it would not make it go into limp mode.
i'm thinking o2 sensor possibly?
Old Feb 3, 2006 | 06:56 PM
dotmichael to you
Old Feb 4, 2006 | 11:30 AM
dotmichael to you
i put my old o2 sensor back in..does the same thing.
i took out the ecu fuse now...gonna let it sit for a few hours and check again.
if it continues, i'll buy a new ecu
Old Feb 6, 2006 | 05:45 PM
dotmichael to you
i just got another ECU..
i put it in..now my idle jumps when the car is in neutral..almost like a TPS problem..but no code..limp mode still there.
i shut the car off..waited a minute and tried to go for a ride.
limp mode still on..i got down the street and my CEL came on..I got a code 12 now.
the 92-00 civic thread has their FAQ codes thread and in there it says:
12 EGR - exhaust gas recirculation lift valve
wtf?
i'll put my original ECU back in and see what happens.
Old Feb 6, 2006 | 07:23 PM
dotmichael to you
i switched my ECU back...no CEL no codes..i didnt rev to see if its in limp mode still..i'm assuming it is though.
is it that the ECU i bought..is bad...or is my ECU unable to read that my car is throwing a code?
Old Feb 7, 2006 | 01:29 PM
dotmichael to you
Old Feb 7, 2006 | 01:41 PM
BrooX's Avatar
Dam Mike, seems like this DA has been nothing but hardships for ya...hope some one could help. Bump
Old Feb 7, 2006 | 01:57 PM
mstolars's Avatar
Default Re: mysterious limp mode (BrooX)
Well, if your car does have an EGR valve and it's stuck open, your car will run like **** because all the exhaust gas is going back into your engine. It's only supposed to open while cruising on the highway.
Old Feb 7, 2006 | 02:34 PM
96ls's Avatar
Default Re: mysterious limp mode (mstolars)
i'm not 100% positive but i don't think da's have egr valves
Old Feb 7, 2006 | 03:29 PM
TunerN00b's Avatar
My 00 gsr went into limp mode on me once. Wouldn't rev up, no power, etc... But I was running it at Willow Springs in 110* weather, and I just assumed the gas wasn't good enough to keep the engine from knocking. After resetting the ECU, everything was perfectly fine.
Old Feb 7, 2006 | 07:56 PM
dotmichael to you
Default Re: mysterious limp mode (TunerN00b)
i'll try resetting the new ECU
Old Feb 7, 2006 | 08:07 PM
dotmichael to you
Default Re: mysterious limp mode (96ls)
can someone post up a picture of where the EGR valve is...i couldnt find it searching..and it doesnt show it in any of my books
Old Feb 8, 2006 | 02:35 PM
dotmichael to you
i reset the ECU the proper way...
still throws a code 12..still the CEL..still the fluncuating idle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote">
is it that the ECU i bought..is bad...or is my ECU unable to read that my car is throwing a code?</TD></TR></TABLE>
still my biggest concern..i need to figure out whether this guy sold me a bad ECU or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96ls &raquo;</TD></TR><TR><TD CLASS="quote">i'm not 100% positive but i don't think da's have egr valves</TD></TR></TABLE>
well my car is throwing the code for it..
Old Feb 8, 2006 | 03:12 PM
96ls's Avatar
was your new ecu the correct one? if it is looking for an egr valve and the car is not equipped with one, it will throw a code
Old Feb 8, 2006 | 05:08 PM
dotmichael to you
obdo pr4
Old Feb 9, 2006 | 12:18 PM
dotmichael to you
