Keyless Remote not engaging actuators
Old Feb 3, 2006 | 09:21 AM
extrmeboost's Avatar
Default Keyless Remote not engaging actuators
So... I have a 95 cx I bought it with an alarm halfway installed but with no remote or anything. It was a wiring mess so I pulled it out except for the power lock actuators (which worked perfectly) I went to Autozone and got their keyless remote entry kit and just wired up the basics (power, ground, lock, unlock)
Everything seems to be wired fine, im assuming, because when I push the buttons on the remote the actuators move. However they dont lock or unlock the doors. It seems that there is not enough power to fully engage the actuators. If anyone has any idea how to fix this the info would be appreciated.
Old Feb 3, 2006 | 09:27 AM
B18C_EJ8's Avatar
You hooked the actuators directly to the outputs on the keyless brain???
If so, that's wrong. Need to use relays to throw power to the actuators... The outputs on the brain are only 200ma. Don't keep trying to use it as wired because you'll burn out the outputs on the brain.
Old Feb 3, 2006 | 09:30 AM
Default Re: (B18C_EJ8)
cool i probably have relays somewhere in the mess of wiring i pulled out with the old alarm. Where do they go though?
Old Feb 3, 2006 | 09:38 AM
Default Re: (extrmeboost)
so I'll be searching for how to wire in the relays, thanks for the help.
Old Feb 3, 2006 | 12:41 PM
so i've wired in the relays and they seem to work fine but they arent sending signal to the actuators???
Old Feb 3, 2006 | 12:48 PM
B18C_EJ8's Avatar
Then you don't have them wired correctly. I'm trying to find a diagram to help ya out, but can't remember where I found the pic...
Old Feb 4, 2006 | 11:57 AM
https://honda-tech.com/zerothread?id=1448163
heres the link to the diagram I used. I tried different variations but still no luck. The relay clicks but no signal to the actuators.
H22AFerio
Feb 25, 2011 12:13 PM
'Accord Ex'
Audio / Security / Video
Dec 3, 2007 12:21 AM
IowayRUlz
Jan 16, 2007 02:20 AM
BDogggUT34
Jun 23, 2005 10:20 AM
PureCRXtasy
Sep 6, 2002 07:32 PM
