Help water leak
Old Feb 3, 2006 | 08:12 AM
red-crx's Avatar
Default Help water leak
This is my frist car its a 1990 crx si, today i went to my car to warm up for school and found out that there was a puddle of water on the floor bed no where else is wet but the floor bed. Any idea what it could be or leaking from? yes it did rained that day
Old Feb 3, 2006 | 08:17 AM
CRX Toad's Avatar
Default Re: Help water leak (red-crx)
search....this has been covered eleventy billion times...or check the FAQ.
Old Feb 3, 2006 | 08:18 AM
Adern's Avatar
Do you have a sunroof?...Check all of your weather stripping for dry-rotting/broken seals. Check under your weather stripping for rust & **** like that.
Good luck.
Edit: Si....duh! I think it's the sunfroof.
Old Feb 3, 2006 | 09:22 AM
gospeedgo1's Avatar
Default Re: (Adern)
floor bed? do you mean the rear trunk area? mine leaked there. try taking off the little access panels on the rear(bottom right and left corner) you will see this tube (clear, about 1/2" in diameter) pull it out and see if it is filled with gooey crap. if it is get a long flat blade or phillps screwdriver and stick in in there and try to knock the crap loose. next open ur sunroof and get hot water and pour it into the sunroof track (the back more so it can go down the rear drain tubes. now you can either get a container for the water to go in or just put it back into the black rubber plug thing that it was in. you can also see the water draining. it if slows or stops, pull the tube back out and pull out the black plastic piece at the end of it, WATCH OUT or you will be covered in smelly nasty water. keep dumping water into the sunroof track until you see it draining well. once its draining well, put the tube back into the black rubber plug and repeat on the other side. it took me about 20 minutes to do mine. good luck
Old Feb 3, 2006 | 11:40 AM
Languid's Avatar
Default Re: (gospeedgo1)
Nice description gospeedgo1. Been thinking about doing this for awhile -- turned out both of mine were clogged. This worked a charm.
Thanks,
Lang
Old Feb 3, 2006 | 11:59 AM
red-crx's Avatar
I ment the floor bed underneth the driver seat, while im at it i minus will do that too. Thanks
Old Feb 5, 2006 | 06:07 PM
XkjeldorX's Avatar
Default Re: (red-crx)
i am having this same problem with my DA. everytime it rains there is a puddle of water on the passenger side floor. i checked under the glove compartment and there was water there when i swiped it with my hand. anyone had this problem and how did u fix it?
murdoko
Mar 27, 2016 09:05 AM
Creature1
Honda Civic (2001 - 2005)
May 5, 2014 10:13 AM
Dekorum
18
Sep 28, 2010 07:55 AM
hOndafienD 04
Dec 9, 2004 11:13 AM
Truecure
Nov 3, 2004 12:33 PM
