B18C1 Swap help
Old Feb 3, 2006 | 08:05 AM
SystemShock's Avatar
Default B18C1 Swap help
I'm dropping a B18C1 in a '94 Civic and wanted to know if the stock tranny will bolt up until I get another one and what kind would be the best to go with? Same with the CV shafts?
Old Feb 3, 2006 | 08:11 AM
DFW's Avatar
DFW
Default Re: B18C1 Swap help (SystemShock)
Wait, what? Are you asking if you can use your stock d-series tranny on the gsr swap? If so, then no.
Everyone will have a diff opinion on what's the "best" tranny is for it. The gsr tranny is perfectly fine if your guna boost it or w/e your plans are. B16/ITR would be better for all-motor. << MY OPINION
**DOHC HaTcH**'s Avatar
nah, you cant use your d series tranny on a b series engine it wont bolt up. good luck
Old Feb 3, 2006 | 08:15 AM
imports automotive's Avatar
what are you trying to ask? if your 94 civic stock tranny would bolt up to your gsr motor.no it wont bolt up. cv shafts use integra cv shafts
Old Feb 3, 2006 | 08:25 AM
This is the first swap that I have ever done so I may ask stupid questions, but I want to make sure that I get everything correct. I'm still new at this and learning. I don't plan on running any boost on it yet. The B18C1 has been slightly modified with Type R pistons and 0.02 bore on the head and a Skunk 2 intake manifold.
Old Feb 3, 2006 | 08:33 AM
sounds like a great setup. hope your happy with it
Old Feb 5, 2006 | 08:49 PM
Default Re: B18C1 Swap help (I LoVe CiViCs)
I think I will once I get it all set up the way I want and learn more about doing this. I have many questions and so few people care to give answers before judging. Will I need to upgrade the motor mounts or will the stock ones from the '94 civic work? Also, what about tha radiator, I'm sure it will need to be replaced as well. What would be the best ingnition for this set up? MSD 6A with a blaster 3 coil, firball distributor and 10mm wires?
Old Feb 5, 2006 | 08:59 PM
DFW's Avatar
DFW
Check the stickies on top in this forum and in the Hybrid forum as well.
You should probably upgrade the mounts since the motor is already out, and you can use your stock civic half radiator. Stock ignition is fine, just get some nice NGK plugs.
Old Feb 5, 2006 | 09:07 PM
Professional Thief's Avatar
If you got the gsr mounts use them and if your radiator is shot then change it otherwise youll be fine the motor should drop right in and plug up and you should be driving all in a days work.
Old Mar 21, 2006 | 10:45 AM
Default Re: B18C1 Swap help (Professional Thief)
Ok, I'm running into a problem with the wiring harness. The engine wiring harness from the b18c1 gsr will not match up to the stock ecu wiring . Any advice on this. I was told that there may be an adapter that I can use for this or do I need to get the harness from the ecu to the engine bay replaced?
Old Mar 21, 2006 | 12:17 PM
fmrprojects's Avatar
the gsr harness should be plug and play. you have to wire in the IAB and the knock sensor. if its a 94 civic, you are going to need a 0bd 1 gsr ecu or chipped p28 ecu
Old Mar 21, 2006 | 12:40 PM
Default Re: B18C1 Swap help (fmrprojects)
ok. I have the ecu, but the engine wiring harness is not plugging into the wiring harness that runs from the ecu through the firewall into the engine bay. the plug ends are different and will not match up. is it possible that the engine wiring harness is the incorrect one?
Old May 11, 2006 | 11:06 AM
I was able to hook up the stock wiring harness, but the car will not start and it is throwing the error code 13: atmospheric preesure. what does this mean? I havent wired in the IAB yet. I can't find the sensor for it on this engine.
JDMEJ2
Jan 17, 2007 05:13 PM
fitboy
Feb 24, 2005 11:29 AM
b22del_sol
Feb 3, 2003 06:17 AM
