no spark or fuel.........
Old Feb 3, 2006 | 06:59 AM
erebunicrx's Avatar
Default no spark or fuel.........
well i recently put a low mileage a6 back into my 90 si hatch.i bought the motor as a short block with no manifolds on it or dizzy. i put a yy8 intake on it and all the rest stock. now yesterdy night i got to start it up and spins over way to easy so immediatly i think timing was 180 off and it was (bought it like that). next i dont smell any gas after tuning it over and over and there was no spark. now is there a relay for both or could it be that the fuel pump is bad and that the dizzy is also bad?
i bought the car itself as a shell so im not sure if the pump was bad from the start. lmk any suggestions thanks.
Old Feb 3, 2006 | 08:05 AM
schwingding's Avatar
i thi nk i reemmber having a similar problem with my car and it was something to do with the dizzy. the cyl position sensor maybe
Old Feb 3, 2006 | 08:35 AM
erebunicrx's Avatar
myabe? lol. anyone with ideas?
Old Feb 3, 2006 | 11:52 PM
mahatma's Avatar
Default Re: (erebunicrx)
I doubt the pump & dizzy went bad simultaneously.....I'd check to see that all the grounds you messed with are clean and tight. And fuses of course.
It's tough to tell because you had to mess with a lot of ****. Did you actually pull the plugs afterwards??
Old Feb 4, 2006 | 03:45 AM
erebunicrx's Avatar
well it does help if you have an ecu in the car...........
Old Feb 4, 2006 | 12:16 PM
thats a good one
High Boost
Feb 4, 2010 07:25 AM
slowassciv33
10
Jul 1, 2007 04:04 PM
patrick4588
May 26, 2006 03:14 PM
lawlerlaw
Nov 16, 2004 01:25 AM
crashtest Sonny
42
Nov 21, 2002 10:34 PM
