OBD-1 and OBD-2 injector Question...
Old Feb 3, 2006 | 02:51 AM
alleyezonme's Avatar
Default OBD-1 and OBD-2 injector Question...
I have the peak and hold ones now with the resistor box. I was wondering if i could use the 290cc satureated ones and just disconnect the box? Would that like 45cc make a difference and be bad or are they the same just one w/ the box? I am shopping for new injectors and was wondering if i could just buy the sat. ones.
thanks
Old Feb 3, 2006 | 09:20 AM
v4lu3s's Avatar
RTFM
the saturated ones need to run at around 50 psi
the peak and hold run at 38 psi
meaning they flow the same in use.
Old Feb 3, 2006 | 09:53 AM
prelittlelude's Avatar
Default Re: (v4lu3s)
you can go to rceng.com and use the injector calculator , but like values said, if your runing an obd1 ecu your ecu is expecting 345cc, if you put in the 290cc you need to take out the resistor box and turn up the fuel press to get them to flow like 345cc..
if your obd2 then your ecu is expecting 290cc , so you could get the 345cc and turn down the fuel press and add a resistor box..
depending on your setup those are your options.
Old Feb 3, 2006 | 12:01 PM
Default Re: (prelittlelude)
ok thanks guys
Navy_Kyle
Aug 6, 2012 12:41 PM
Pendmn
Jul 30, 2012 11:55 AM
91EF919
Oct 9, 2008 06:34 PM
BlownBlackSi
Sep 8, 2006 09:38 AM
zseeanz
Mar 11, 2005 07:46 AM
