Turbo oil Feed Location?
Old Feb 3, 2006 | 12:41 AM
chrisbell37's Avatar
Default Turbo oil Feed Location?
im going to be putting a turbo on my B16A2 eg civic and im trying to find out where will be a good place to locate the turbo oil feed line from the engine?
If anyone could help it would be most appreciated. It would be great if you have pics too?
Thanks
Chris
Old Feb 3, 2006 | 01:07 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Turbo oil Feed Location? (chrisbell37)
either the pressure sender using a tee (not ideal) or a sandwich plate (best)
Old Feb 3, 2006 | 05:02 AM
RedR's Avatar
Default Re: Turbo oil Feed Location? (wantboost)
didnt quite understand if u wanna know where to get the oil from but here is how u hook up your oil feed line
https://honda-tech.com/zerothread?id=1263795
Old Feb 3, 2006 | 06:36 AM
tgreaves's Avatar
Default Re: Turbo oil Feed Location? (RedR)
I wouldnt run the oil pressure switch "T".. In my opinion it adds too much weight just hanging off the back of the block.. What I do it get a 1/8"BSPT to 1/8"NPT fitting and screw that into the oil pressure fitting on the back of the block.. And then run a line from that into a oil block(get them from mcmaster.com) And put the stock oil pressure sensor and turbo feed line comming from the block.. Mount the block on to the firewall..
B18EG6
Mar 25, 2012 06:20 AM
totsie7944
May 1, 2008 04:52 AM
wade
Oct 10, 2004 07:38 PM
gigantor
Feb 11, 2003 08:06 AM
slingshotsi
Sep 9, 2001 06:11 PM
