wheel stud replacement?
how many people have done this and the wheel bearing was ok, not having to replace it and how many have had to replace the bearing and how to do it
with out a machine shop?
i have replaced integra studs and there is no way you can do this at home dont even bother unless you have a huge hydrolic press and a new bearing you basickly distroy the bearing to get to the studs so buy studs i recomend get all 4 new studs becouse if one broke i bet the others will too very soon and there only 99cents each and get the new bearing $40-$50, and now take it to a shop with a hydrolic press and have them do it. thats one way, the other is buy the whole steering knukle on ebay.
i thought i was going to have to do this.. it looked so simple, but then i couldnt get the stud out b/c there is a peice behind it... luckily i just rethreaded the stud and i was ok.
ill try to get a thread with a grinding wheel, if not i hvae a slide hammer but do i still need to replace bearing, if bearing looks good should i still replace it?
91integra_rubio
Apr 28, 2009 11:18 PM
EFstyle
Nov 23, 2008 07:08 PM
