Throttlebody plate supposed to fully closed at idle?
I'm having idle issues . I have the str 68mm TB and when its fully shut and sticks. I adjusted it open just enough to keep it from sticking and i think maybe air is getting through because the car tends to idle a little high and fluctuates some too. Once the thermo opens the fluctuation stops but the idle is still high. I have no FITV so its not that . Is the throttle plate supposed to be totally sealed at idle? And if so i could just seal the IACV passge and the car would shut off ? I haven't tried this because its too cold to mess with the car and let me know where the extra air is coming from?
So that plate should be 100% shut with no air flowing fast it when shut? I think before i put this on the car i may have noticed i could see light around the plate when i stuck it up to the light , so i may have to give str a call and see what they say , if in fact the plate is supposed to be sealed. I have heard stories about this Tb's being a little troublesome , hopefully this don't prove to be a reason to get something different
The throttle rotor should be closed completely. The car accepts air at idle throught the IAC. I am pretty sure you can't block off the IAC because of cold start ups. My car ran like crap without the IAC working correctly.
b16acrxer
Aug 31, 2004 09:02 AM
