integra problem!!sweaking.... need help!
well to start off with i drive a 2000 gsr and the problem i have with it is that whenever i stop or i turn the wheel to the right, my right side starts sweaking, im getting annoyed, i jus changed my brakes 4 months ago and resurfaced my rotors..... can it be the shocks making the noise??what can it possibly be................. Thanks
hey man i would check your axle joints first and inspect the boots make sure there are no rips in them. if that looks good then mabye it could be power steering but check the axle joints first i bet thats the problem
most likely its your CV. If it only happens when you turn right, most likely its torn or just toast. pop it up on a jack and look around the axle, if you have grease all over the place then its dead and time for a replacement. Each side is around $80 w/abs.
Same thing happened to me a little while ago. Fun times :D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justin.parker »</TD></TR><TR><TD CLASS="quote">pop it up on a jack and look around the axle, if you have grease all over the place then its dead and time for a replacement.</TD></TR></TABLE>
can't miss it. Looks like the earth took a **** on your axle and surrounding area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed DC2 »</TD></TR><TR><TD CLASS="quote">can't miss it. Looks like the earth took a **** on your axle and surrounding area.</TD></TR></TABLE>
+1 :D
+1 :D
