no torque over 6500 rpm !!!
Old Feb 2, 2006 | 04:50 PM
water's Avatar
Default no torque over 6500 rpm !!!
hi every ones i'm working on a atv ... but it's a honda atv ( 400ex) i had put a turbo on it and a efi system (megasquirt) dans it's work perfectly but , at higher RPM (over 6500) i got a pitfall of torque . i make all the test i can event think but no result.
BUT!!!!! Wen i remove the intercooler , the rev goes up to 10Krpm with no problem (but i got no torque, to much air temp
My air/fuel is perfect ( 11:1) on all the range and it's verify on a wideband , not a autometer gage . my boost it's constant on all the range .
I feed the engine with 50/50 C-16 and pump gaz.
there is the specs:
-turbo - K03 of TDI (pretty smal) but flow 210CFM at 15PSI
-firefly intercooler
-megasquirt with 2x 240cc/min
-full ported head with heavy duty spring
-stock cam
-all the **** it goes around to work.....
i'have no idee on What to check .
PS; sorry for my english , i make my best
Old Feb 2, 2006 | 05:17 PM
The Weather Man's Avatar
Probably because torque at high RPM = horsepower.................
Old Feb 2, 2006 | 05:20 PM
coneheadsracing's Avatar
Default Re: (TheKINGPin)
possibly out of the turbos efficiency range... or you need a bigger exhaust.
Old Feb 2, 2006 | 05:21 PM
LSTEG96's Avatar
edit: should have read more.
Old Feb 2, 2006 | 05:35 PM
LSVtechnologytur...'s Avatar
Default Re: (LSTEG96)
i dont really know much about atv's, but maybe its the stock cam that stops making power?
Old Feb 2, 2006 | 05:36 PM
water's Avatar
Default Re: no torque over 6500 rpm !!! (water)
thi king of turbo can put over 170hp on a TDI and i'am right on the turbo efficiency range. i Have try a bigger turbo like K14 , same problem. wen i remove the intercooler , i can goes up tu 10K but with , 6.5k is the max. i Have try a intercooler of eagle talon 1gen, same problem and i don't thing i got to much pressur drop with a intercoole of 180 hp on a bike of 80 ? every line is 1k rpm
thanks -Walter
Old Feb 2, 2006 | 06:45 PM
mrbsponge's Avatar
i have turbo'd a 4 wheeler before and we had issues with the 4 stroke motors, but we switched to an HKS turbo, i cant remember which one and it seemed to work well.
we had more luck with the 2 strokes tho
Old Feb 2, 2006 | 07:07 PM
NJIN BUILDR's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">we had more luck with the 2 strokes tho</TD></TR></TABLE>
A shop I worked at years ago made turbo kits for carburated Polaris triple snowmobiles.You could melt a piston to the pin in a nanosecond.It was fun to watch them on the dyno.
Glenn
Old Feb 3, 2006 | 04:42 AM
Jamez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">Probably because torque at high RPM = horsepower.................</TD></TR></TABLE>
Huh... torque at any RPM = HP
Old Feb 3, 2006 | 11:29 AM
Default Re: (Jamez)
i used a dsm at 15 psi on my car, so i don't think that is your problem.... I would think that would work fine. What is your air fuel at with the intercooler above 6500... still 11:1 also. Maybe, your actually cooling the air more, i don't know. My sea-doo has a vortech supercharger, 4-stroke 215 hp i think.... The intercooler is super small though.
Old Feb 3, 2006 | 11:41 AM
m R g S r's Avatar
<FONT SIZE="5">post pics bich!!!!!!!!!!!!!!!!!!!</FONT>
Old Feb 3, 2006 | 11:44 AM
beepy's Avatar
The problem is probably a glitch in the MegaSquirt.
Old Feb 3, 2006 | 11:46 AM
Unsivil_audio's Avatar
What size exhaust are you running?
Old Feb 3, 2006 | 01:44 PM
water's Avatar
Default Re: (coneheadsracing)
my air/fuel il correct on all de rpm range but today i notice something, my charge pipe before the throttle bodies is about 1.5 inch, the 400ex is a 1 cylinder. my flow is unregular ( 1/4 of the time on the move and 3/4 of time on wait) and i thing i need a very big plenium( like 1 liter for 400cc) to keep the velocety regular in the intercooler. i'm gonna try this towmorrow. there is the wideband
the exhaust is a pipe of 2.5 galvanise 1 feet long, no restriction possible.the megasquirt had a time who rool on buckle (0 to 255) and it does'nt reset.
Old Feb 3, 2006 | 01:53 PM
SOHC_MShue's Avatar
Default Re: (water)
thats strange. I can't figure out what the problem might be.
quicksilver1689
Aug 24, 2007 02:39 PM
Westrock2000
Jun 29, 2007 03:58 PM
civic_minded1987
Honda Civic (2001 - 2005)
40
Nov 22, 2006 03:53 PM
RR98ITR
Mar 31, 2003 11:49 AM
CPR
Apr 8, 2002 09:17 AM
