Noob Question - B18a / B18b
Old Feb 2, 2006 | 04:01 PM
RustyRex's Avatar
Default Noob Question - B18a / B18b
What are the differences between the 2 motors?
I know one comes in the da, and the b in the dc.
Are they interchangeable etc? What are the differences?
Old Feb 2, 2006 | 04:23 PM
97turboteg's Avatar
Default Re: Noob Question - B18a / B18b (RustyRex)
overall there the same motors, dont quote me on it, but im pretty sure im right. why you ask?
Old Feb 2, 2006 | 04:30 PM
posHonda's Avatar
90-91 B18A = 130hp OBD0
92-93 B18A = 140hp OBD1
94-95 B18B = 142hp OBD1
96-01 B18B = 142hp OBD2
Old Feb 2, 2006 | 04:46 PM
RustyRex's Avatar
My main thought is are the motors interchangeable?
Old Feb 2, 2006 | 05:06 PM
nickG's Avatar
Default Re: (RustyRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RustyRex &raquo;</TD></TR><TR><TD CLASS="quote">
My main thought is are the motors interchangeable?</TD></TR></TABLE>
basically
Old Feb 2, 2006 | 05:07 PM
RidinStock's Avatar
Yes, except you have to take ECU's into consideration. B-series is b-series is b-series, so your b-series motors (b16,b18,b20) will all fit on b-series mounts.
Old Feb 2, 2006 | 07:31 PM
RustyRex's Avatar
and all wiring harnesses will interact or can?
Old Feb 2, 2006 | 08:59 PM
SiR AuToBoT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RustyRex &raquo;</TD></TR><TR><TD CLASS="quote">and all wiring harnesses will interact or can?</TD></TR></TABLE>
yes
Old Feb 2, 2006 | 09:00 PM
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">90-91 B18A = 130hp OBD0
96-01 B18B = 142hp OBD2</TD></TR></TABLE>
CORRECTION
94-95 B18B = 145 HP.
Old Feb 2, 2006 | 10:10 PM
RustyRex's Avatar
well could i put any b18b into a car that came with a b18a straight?
Old Feb 3, 2006 | 01:15 PM
RidinStock's Avatar
Yes, and if the ECU's have different obd numbers, you will have to get a conversion harness. What swap are you considering exactly? I'm tired of answering vauge questions. Can you provide a little more detail?
Old Feb 5, 2006 | 01:50 PM
XkjeldorX's Avatar
Default Re: (RidinStock)
one question. i have a 93 b18a and im going to change the whole valve train. at this point it wont matter to get a b18b head for 3 hp gain right? or should i go to a b18b head instead?
thanx
Old Feb 5, 2006 | 05:25 PM
fast4teg's Avatar
Default Re: (XkjeldorX)
If you are going to do that why not get a vtec head. you are still going to do about the same amount of work (plus rerouting oil lines) but for the extra 30-40 hp would be worth it.
either way you will need to either get a new ecu or make sure you get a compatable head look at the chart above to determine the proper head to get if you are going to try to avoid changing the ecu.
Old Feb 5, 2006 | 05:41 PM
XkjeldorX's Avatar
Default Re: (fast4teg)
i already have a dohc vtec in my hatch and i just want to have a built ls on another car. if it come down maybe later on i can just switch heads and make an lsvtec.
i was just thinking to get a b18b obd1 head so i wouldnt have to change ecu's. but will it be worth it to buy a b18b head if the whole valvetrain is to be changed?
thanx
effinnwackk
21
Jul 1, 2005 05:50 AM
the.hamburglar
May 27, 2005 05:24 AM
gildo86
May 31, 2004 11:41 AM
wanabecivicex
Jul 10, 2002 08:46 AM
