We Need VTEC!
Old Feb 2, 2006 | 02:18 PM
Jay.D.Em!'s Avatar
Default We Need VTEC!
My cousin and I just finished a b16a1 swap into his crx, wiring is fine everything is finished car runs really good, speedometer cable is plugged in however is not working..so neither is the VTEC. A good friend of mine who has done about 20 dpfi-mpfi B16 swaps says it needs some sort of speed sensor? I also heard him mention 90-93 integra, does anyone know exactly what the name of this part could be and if it is from a 90-93 integra or 99+ SI? thanks
Old Feb 2, 2006 | 02:36 PM
Jay.D.Em!'s Avatar
Default Re: We Need VTEC! (ILoveMyED6)
i just found out its the speedo cable..i overlooked that he kept the stock one..need a 90-93 teg cable.. but thanks for reading!
Old Feb 2, 2006 | 02:40 PM
Pee Wee's Avatar
did you keep the electronic vss that came with the B16? if you did you need to take it out and use the d series cable vss.
Old Feb 2, 2006 | 07:29 PM
jccrxtuner916's Avatar
i have the same problem.... i already put in the d series speed senser that went on the tranny... after changing the speedometer i finally got some reading... but the speed is off by about 25 mph.. so if im doing 50... only read 25-30.... and i still code 17 on my ecu.... what to do??? anybody?? oh ya not to mention no VTEC.......
Old Feb 2, 2006 | 11:18 PM
VtecSyndrome's Avatar
Default Re: (jccrxtuner916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jccrxtuner916 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem.... i already put in the d series speed senser that went on the tranny... after changing the speedometer i finally got some reading... but the speed is off by about 25 mph.. so if im doing 50... only read 25-30.... and i still code 17 on my ecu.... what to do??? anybody?? oh ya not to mention no VTEC....... </TD></TR></TABLE>
Shoulda started your own thread but it sounds like you need a new speedometer, I don't know what else could cause it to work and be that off. Replace the speedometer, it 's easy to replace and you don't need an entire cluster to do so, I think it's only 4 screws to remove once the cluster is out.
Old Feb 3, 2006 | 10:03 PM
Jay.D.Em!'s Avatar
Default Re: We Need VTEC! (Pee Wee)
yea i kept the vss that came with it.. i just have to order a 90-93 teg speedo cable from the acura dealership..
Old Feb 3, 2006 | 10:38 PM
so using the d series VSS and a 90=93 integra speedo cable would fix it??? i already change the speedometer itself and still not working..
Old Feb 4, 2006 | 12:41 AM
Rywire's Avatar
put the d series(stock one) in the b16 tranny, and plug the factory crx speedo cable in, make sure its tight, and the ring it on right... Thats all you need
Ryan
88_hatch_ls
Sep 4, 2013 05:47 AM
jccrxtuner916
13
Jan 30, 2006 07:52 AM
JohnCRX
Jul 29, 2004 09:00 AM
shane
May 26, 2003 10:09 PM
JDM CRX
Oct 20, 2002 10:54 PM
