whats wrong with my motor?
Old Mar 24, 2002 | 09:09 PM
swarsing's Avatar
Default whats wrong with my motor?
95 b18c1 ,using about a quart of oil every 3rd tank of gas and poor mileage at that about 20 mpg,no leaks vissible motor is completely dry and no smoke at all until about 7500rpm,and the motor seems to be down on power for the past couple weeks,and there are no mods to the motor at all .thanks
Old Mar 24, 2002 | 09:25 PM
Ferrell's Avatar
Default Re: whats wrong with my motor? (swarsing)
valve pan gasket??
Old Mar 24, 2002 | 09:48 PM
96b18c's Avatar
Default Re: whats wrong with my motor? (Yes it's VTEC)
what the hell is a valve pan gasket...never heard of it?
Old Mar 25, 2002 | 06:59 AM
RedTeg95's Avatar
Default Re: whats wrong with my motor? (96b18c)
It's right next to the spark plug filter.
But seriously, you may want to start by checking the compression in your cylinders.
Old Mar 25, 2002 | 08:43 AM
Fooser's Avatar
Default Re: whats wrong with my motor? (RedTeg95)
Check your PCV valve to. $3 fix and its pretty easy. I replaced mine and it was totally clogged with only 30k on it. Since I replaced it I'm getting alot better gas mileage. I would say 20-30 miles more a tank.
[Modified by Fooser, 5:46 PM 3/25/2002]
Old Mar 25, 2002 | 10:38 AM
bocian's Avatar
Default Re: whats wrong with my motor? (Fooser)
heres a dumb question, where is the PCV valve located and what does it do?
Old Mar 25, 2002 | 10:44 AM
PM-Performance's Avatar
Default Re: whats wrong with my motor? (bocian)
i got a nice spark plug filter ill sell you . . . ill even throw in a free can of brake lubricant
Old Mar 25, 2002 | 11:19 AM
Fooser's Avatar
PCV = Positive Crankcase Ventilation valve. The purpose of this is to capture blow by gases from escaping into the atmosphere. If its clogged then the blow by gases will escape alot easier resulting in bad gas mileage and even a bad idle.
The valve is located under your intake manifold. Its a pretty easy fix. I would recommend just buying a new one for $3 at any auto parts store. All you need is a set of needle nose pliers or something to squeeze the clamp so you can get the valve off the hose. Thats the hardest part. I had to use a small flat head screw driver to pry it off. Took me a total of 15 minutes to do this fix for my very fist time. Oh ya make sure your car is cool enough to touch cause your right by the intake which gets HOOOOT..
Old Mar 25, 2002 | 11:31 AM
bocian's Avatar
Default Re: whats wrong with my motor? (itr206)
thanks fooser, you're the man!
im going to do this today and hopefully, ill see better gas mileage.
Old Mar 25, 2002 | 11:38 AM
Fooser's Avatar
Oh ya to test your valve to see if its clogged just shake it. If its still good you will hear something inside of it rattle around. You will know what I mean when you buy the new one. Compare sounds. You can also pinch the hose and the valve should make a clicking sound if its good. The helms manual tells you to pinch the hose. Its easier just to take it out and shake it.
[Modified by Fooser, 8:39 PM 3/25/2002]
Old Mar 25, 2002 | 09:52 PM
LS_racer's Avatar
so this might explain my sudden case of *** gas milage? hmmm, good thing I ordered one last week, should be here tomorrow. I'll post if I can tell any difference in the next couple of days right now I've gotten less that 100miles to over a half gallon, granted its mostly city driving and I did do a couple of 1/4 passes, which might have eaten up some gas but still it's pretty **** poor from a milage champ like an integra... glad I read this thread.
Old Mar 26, 2002 | 03:40 PM
LS_racer's Avatar
Default Re: whats wrong with my motor? (LS_racer)
just an update, I installed my new PCV valve and after looking at the old one, I 'm very glad I did. I did a short test drive with the new valve and I think most of the whistle I was noticing before is gone but I won't be able to tell if this affected that noise until a bit more driving. I'll let you know how the gas mileage changes too. it better go back up...
the install took maybe ten minutes most of which was looking for some vice grips to pull the valve out of the slot in the IM, that thing's really in there. and pushing it back took a bit more than I expected but it's really straight forward to replace.
Old Mar 26, 2002 | 06:21 PM
TurbothisLS's Avatar
Is that what the whistling sound is? I keep on hearing this weird whistling noise even when i stuck the stock intake back on.
let me know about this..thanks! Car has 49k on it.
Old Mar 26, 2002 | 06:32 PM
birdee's Avatar
where can i get pcv valves from?...dealership, local auto store?
thanks
Old Mar 26, 2002 | 06:42 PM
KooK's Avatar
Mustang Sally
Default Re: whats wrong with my motor? (birdee)
Man... If my engine was doing that, I'd be happy!! Wouldn't know what the problem was but I bet I could figure it out when I rebuild it!
Old Mar 26, 2002 | 08:21 PM
bocian's Avatar
like 2.49 at r and s strauss. the have them everywhere, pep boys, autozone... etc
hopefully it will make a difference.
can anyone else verify that they are now getting better gas mileage after the pcv valve was changed
prf0188
16
Feb 7, 2008 10:27 PM
EK9 BEEZLER
Jul 28, 2005 05:22 PM
delguiner
May 18, 2004 04:16 PM
Smeeg Heed
Apr 14, 2004 08:49 PM
mickey513
Feb 1, 2003 02:51 AM
