trying to relocate main relay, why are there doubles of some wires?
Old Feb 2, 2006 | 11:13 AM
3.point.2's Avatar
Default trying to relocate main relay, why are there doubles of some wires?
So ive been going through my share of main relays and im pretty sure its because im getting water in them some how. I cant find the leak so instead im trying to just relocate the main relay to a dry spot. My manual says theres 7 wires going into it however when i went to extend the wires i found theres 2 grounds, 2 wires to the ECU and 2 to the ignition making a total of 10 wires. Why do these three have doubles and can i just extend them with the same wire or should i get three more wires to keep it how it is?
car is a 95 cx.
Old Feb 2, 2006 | 11:29 AM
nello a.'s Avatar
dont know crap about wiring/harnesses. but, if honda did it that way, i'm sure they had a good reason.
Old Feb 2, 2006 | 11:36 AM
nocturnaldragon's Avatar
Default Re: trying to relocate main relay, why are there doubles of some wires? (h23eg)
You can extend them with a single wire. There are two because it goes to more then one location somewhere else in the car.
The blue white for example is a power wire, that tells the car is switched on I belive so it sends power to the relay and to the ecu.
Old Feb 2, 2006 | 12:16 PM
postman's Avatar
check a diagram but they could be feedback wires which you def. dont want to eliminate
Old Feb 2, 2006 | 12:26 PM
Default Re: trying to relocate main relay, why are there doubles of some wires? (postman)
I did check a diagram, the feed more then one item which is why there the same color.
Old Feb 2, 2006 | 01:02 PM
3.point.2's Avatar
Default Re: trying to relocate main relay, why are there doubles of some wires? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">You can extend them with a single wire. There are two because it goes to more then one location somewhere else in the car.
The blue white for example is a power wire, that tells the car is switched on I belive so it sends power to the relay and to the ecu.</TD></TR></TABLE>
thanks, i think i am gonna just get extra wire and extend all 10 wires. No need to get lazy when it comes to wiring.
90R3x
23
Jan 14, 2020 06:57 PM
crxaddikt
Jun 23, 2017 05:08 PM
Kingb16a2
14
May 21, 2010 12:26 AM
foumer
Dec 21, 2005 10:34 AM
JDubya
Jun 10, 2003 10:18 PM
